Barracuda door differences ? ? ? #2507906
06/13/18 01:45 PM
06/13/18 01:45 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
Hello all,
I have a 1970 Barracuda convertible that may require doors. I am trying to get a handle on what differences there are between the doors on the '70 to '74 cars. Also, is there any difference with it being a convertible? It seems that they will all work as far as bolting up goes. Just hoping to find out how specific my search needs to be.
Thanks in advance,
Paul
1970 Barracuda Convertible
1970 Newport Convertible
1970 Satellite Convertible
1974 'Cuda shell - '71 conversion
1988 Oldsmobile Cutlass w/455
2003 RAM3500 CTD
2007 Caliber R/T AWD
2007 Magnum SRT-8
2016 Chrysler Town & Country
Re: Barracuda door differences ? ? ? [Re: RCKTMN] #2508100
06/13/18 07:48 PM
06/13/18 07:48 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
One thing is that the window felt slides in slots on the 70 door and the 72 up has screws attaching them on and the glass is different. I think that the conv door has a wedge thing on the back of it, I will look at mine when I get a chance and let you know for sure.
Re: Barracuda door differences ? ? ? [Re: magiccuda] #2508190
06/13/18 11:24 PM
06/13/18 11:24 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
Thanks magiccuda,
I appreciate that.
Paul
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: Barracuda door differences ? ? ? [Re: RCKTMN] #2508209
06/14/18 12:11 AM
06/14/18 12:11 AM
n.c.
geo. Offline
geo.  Offline
n.c.
I know this is a Barracuda, but I'd bet they're similar.
1970 Challenger doors are noticeably heavier than the '72-4 doors.
If you look at the side impact bracing it's a lot more substantial on the '70 doors.
Re: Barracuda door differences ? ? ? [Re: geo.] #2508236
06/14/18 01:45 AM
06/14/18 01:45 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The change over on the window felt attachment was in 1971. The 71 to 74 E-Body outer felts attached with screws while the 70 applications used the clips.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Barracuda door differences ? ? ? [Re: RCKTMN] #2508482
06/14/18 05:16 PM
06/14/18 05:16 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
The upper window guide bolt holes are
different I think the 70s are slots and all others are round
NS1AAR
Re: Barracuda door differences ? ? ? [Re: RCKTMN] #2508502
06/14/18 06:15 PM
06/14/18 06:15 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Lock mechanisms are different. On 70's, you have to lock the door from the outside, with the key. At some point, 71-up-??, you could press the inside door lock and close and lock the door.
Also, if you're mixing and matching hardtop and convertible doors, the door class is different on the two body styles.
Re: Barracuda door differences ? ? ? [Re: 318 Stroker] #2508773
06/15/18 10:31 AM
06/15/18 10:31 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Also on 70 - 71 convertible doors there are dimples where you drill for the wedges. On the 72 - 74 they are not there but can still be drilled.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Barracuda door differences ? ? ? [Re: RCKTMN] #2509318
06/16/18 01:18 PM
06/16/18 01:18 PM
Massachussetts
RCKTMN Offline OP
RCKTMN  Offline OP
Massachussetts
Thanks for the great info!
Paul
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: Barracuda door differences ? ? ? [Re: 318 Stroker] #2510003
06/18/18 02:24 PM
06/18/18 02:24 PM
LA & L.A.
MoparPosterChild Offline
LA & L.A.
I wonder if the lock mechanisms are interchangeable? Could I use a 71 style on my 70 doors?
2018 Dodge DEMON #18
1970 Plymouth Duster 406" Stroker
1969 Charger 500" Stroker
1964 Dodge Polara 426 GEN III HEMI
1970 Plymouth Cuda Hellcrate Project car
1974 Dodge Ramcharger Project car
2017 Chrysler Pacifica Limited
2017 Ram 3500
2012 Dodge Caravan R/T
1972 Charger Mopar 392 HEMI Stolen
2008 Challenger SRT-8 Gone
2010 Challenger SRT-8 Gone
2006 Charger SRT-8 Gone
2007 Charger R/T Gone
