Barracuda door differences ? ? ?
#2507906
06/13/18 01:45 PM
06/13/18 01:45 PM
Posts: 283 Massachussetts
RCKTMN
Massachussetts
Hello all,
I have a 1970 Barracuda convertible that may require doors. I am trying to get a handle on what differences there are between the doors on the '70 to '74 cars. Also, is there any difference with it being a convertible? It seems that they will all work as far as bolting up goes. Just hoping to find out how specific my search needs to be.
Thanks in advance, Paul
1970 Barracuda Convertible 1970 Newport Convertible 1970 Satellite Convertible 1974 'Cuda shell - '71 conversion 1988 Oldsmobile Cutlass w/455 2003 RAM3500 CTD 2007 Caliber R/T AWD 2007 Magnum SRT-8 2016 Chrysler Town & Country
Re: Barracuda door differences ? ? ?
[Re: magiccuda]
#2508190
06/13/18 11:24 PM
06/13/18 11:24 PM
RCKTMN
Massachussetts
Thanks magiccuda,
I appreciate that.
Paul
[Re: geo.]
#2508236
06/14/18 01:45 AM
06/14/18 01:45 AM
Posts: 306 Georgia
69bfan
Georgia
The change over on the window felt attachment was in 1971. The 71 to 74 E-Body outer felts attached with screws while the 70 applications used the clips.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: RCKTMN]
#2508482
06/14/18 05:16 PM
06/14/18 05:16 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
The upper window guide bolt holes are different I think the 70s are slots and all others are round
NS1AAR
[Re: RCKTMN]
#2508502
06/14/18 06:15 PM
06/14/18 06:15 PM
Posts: 4,319 St. Louis, Mo
318 Stroker
St. Louis, Mo
Lock mechanisms are different. On 70's, you have to lock the door from the outside, with the key. At some point, 71-up-??, you could press the inside door lock and close and lock the door.
Also, if you're mixing and matching hardtop and convertible doors, the door class is different on the two body styles.
[Re: 318 Stroker]
#2508773
06/15/18 10:31 AM
06/15/18 10:31 AM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Also on 70 - 71 convertible doors there are dimples where you drill for the wedges. On the 72 - 74 they are not there but can still be drilled.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: RCKTMN]
#2509318
06/16/18 01:18 PM
06/16/18 01:18 PM
RCKTMN
Massachussetts
Thanks for the great info!
Paul
[Re: 318 Stroker]
#2510003
06/18/18 02:24 PM
06/18/18 02:24 PM
Posts: 551 LA & L.A.
MoparPosterChild
LA & L.A.
Also, if you're mixing and matching hardtop and convertible doors, the door class is different on the two body styles. I wonder if the lock mechanisms are interchangeable? Could I use a 71 style on my 70 doors?
2018 Dodge DEMON #18 1970 Plymouth Duster 406" Stroker 1969 Charger 500" Stroker 1964 Dodge Polara 426 GEN III HEMI 1970 Plymouth Cuda Hellcrate Project car 1974 Dodge Ramcharger Project car 2017 Chrysler Pacifica Limited 2017 Ram 3500 2012 Dodge Caravan R/T 1972 Charger Mopar 392 HEMI Stolen 2008 Challenger SRT-8 Gone 2010 Challenger SRT-8 Gone 2006 Charger SRT-8 Gone 2007 Charger R/T Gone
