Page 1 of 3 1 2 3
High performance engines and pcv systems #2508149
06/13/18 10:17 PM
06/13/18 10:17 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What needed to keep the oil in the engine at higher rpm's. In my 511 i have a pcv valve in the pass side cover and a -10 hose on the driver side cover connected to the air cleaner. Not enough as it blows out more oil now than it did with just 2 breathers. Should there be breathers in the covers as well as pcv valve?
Re: High performance engines and pcv systems [Re: mopar dave] #2508158
06/13/18 10:32 PM
06/13/18 10:32 PM
IN
ahy Offline
ahy  Offline
IN
The "classic" setup on a (moderately) high po engine is PCV valve on pass side and an open VC breather on drivers side. Valve covers well baffled on both sides.
This has worked well for me on a warm 496 that sees road track time.
I guess the 10AN line to your air cleaner is a problem. I guess a fouled air cleaner element?
A high cylinder pressure high po engine will have more blow by when hammered vs a stock engine (even if the hi po engine is healthy and tight). It needs to have a free vent to atmosphere for those times. The vent will act as an air intake for the crankcase when cruising... it lets air in and the PCV sucks fumes out.
Re: High performance engines and pcv systems [Re: ahy] #2508160
06/13/18 10:36 PM
06/13/18 10:36 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. So makes no difference which side pcv valve is on? Any harm with the -10 hose to air cleaner and a breather in same cover?
Re: High performance engines and pcv systems [Re: ahy] #2508162
06/13/18 10:39 PM
06/13/18 10:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, I do the PCV valve on passenger cover and a K&N open breather modded to fit the stand on the drivers side cover.
I've used cheap, chrome Mr. Gasket breathers in the past and they simply can't flow enough air at higher rpm. Years ago my dipstick would blow out of the tube because of crankcase pressure buildup with one after 4.56 gear install..
'63 Dodge 330
11.19 @ 121 mph
Re: High performance engines and pcv systems [Re: mopar dave] #2508181
06/13/18 11:15 PM
06/13/18 11:15 PM
AndyF Offline
AndyF  Offline
I use a #12 Peterson breather. They are really well built and screw right into the valve cover. If the Peterson breather doesn't work then you can hook up a remote breather tank. I've done the remote tank before and it works really well for big race engines. Mount the remote tank up by the radiator and run a #12 line from the valve cover.
Re: High performance engines and pcv systems [Re: AndyF] #2508189
06/13/18 11:23 PM
06/13/18 11:23 PM
Mt Morris Michigan
Mt Morris Michigan
2 of those breathers on 1 cover would look cool and provide plenty of venting as well.
Re: High performance engines and pcv systems [Re: mopar dave] #2508227
06/14/18 01:10 AM
06/14/18 01:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The clean air intake and PCV to the manifold should be separated by the entire engine if possible to pass all the crankcase vapor through them. If they're both on one cover the case is never "flushed" and accumulates sulfuric acid and combustion products.
Severe blowby is generally ring seal going away, and you already know what fixes that.
A much bigger pan volume (longer, deeper, wider), for more air not more oil, reduces the amplitude of pressure spikes, so will any extension to the valley or covers. It's only a buffer, so shape doesn't matter as long as the connection to the air under the crank is large.
Boffin Emeritus
Re: High performance engines and pcv systems [Re: polyspheric] #2508237
06/14/18 01:57 AM
06/14/18 01:57 AM
Mt Morris Michigan
Mt Morris Michigan
Maybe thats part of my problem. 8qts in a 7qt pan.
Re: High performance engines and pcv systems [Re: mopar dave] #2508262
06/14/18 07:21 AM
06/14/18 07:21 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
As Jeff
Mentioned, more cubic inches need more pan volume not taken up by oil.
Re: High performance engines and pcv systems [Re: mopar dave] #2508268
06/14/18 08:18 AM
06/14/18 08:18 AM
jersey
Spaceman Spiff Offline
jersey
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: High performance engines and pcv systems [Re: Spaceman Spiff] #2508291
06/14/18 10:07 AM
06/14/18 10:07 AM
Mt Morris Michigan
Mt Morris Michigan
My PCV valve is a Billet style from billet specialties. Too much oil in the pan is not helping either. I will be installing an oil cooler this weekend, that will get the oil level back down. I also have an oil catch can im not using that i could install or use the tall breathers that Andy posted. Moroso also has something simular.
Re: High performance engines and pcv systems [Re: mopar dave] #2508297
06/14/18 10:22 AM
06/14/18 10:22 AM
an8sec70cuda Offline
Pictured below is my wedge motor in my other car. Two -10 lines tee'd into a breather tank mounted next to the radiator. Works great. I have a vacuum pump on my hemi, but honestly, I wish I'd just done the same thing on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: High performance engines and pcv systems [Re: mopar dave] #2508313
06/14/18 10:43 AM
06/14/18 10:43 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave, do you valve covers have baffles in them? My small block Indy covers only had a breather in each one with no provision for a pcv valve. I drilled a hole for a pvc valve and welded in baffles in each one then plugged the breather on the pvc side. It's turned 7200 several times and never blew any oil out or had any in the pcv hose.
When it was on the dyno it picked up 3 hp with the pcv valve hooked up on back to back pulls.
Re: High performance engines and pcv systems [Re: mopar dave] #2508325
06/14/18 11:06 AM
06/14/18 11:06 AM
tboomer Online work
tboomer  Online Work
Dave..8 quarts of oil in a 7 quart pan? Isn't that creating problems? Just curious here... work
Re: High performance engines and pcv systems [Re: mopar dave] #2508370
06/14/18 01:31 PM
06/14/18 01:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
BIG problem try the opposite, less oil in a larger capacity pan and I run 6 qts. in an 8 qt. pan and zero issues forever........As we talked, my pcv is in a Ford truck breather full of foam which is higher up off of the valve cover helping to keep oil out of the manifold and more vapor as designed plus a home made oil separator right at the manifold............ thumbs Breather on one side, pcv on the other to pull THROUGH the engine......
Re: High performance engines and pcv systems [Re: tboomer] #2508445
06/14/18 03:43 PM
06/14/18 03:43 PM
Mt Morris Michigan
Mt Morris Michigan
Yes. I thought it was a 8qt pan when i filled it. My mistake
Re: High performance engines and pcv systems [Re: justinp61] #2508446
06/14/18 03:44 PM
06/14/18 03:44 PM
Mt Morris Michigan
Mt Morris Michigan
Yes i do have baffles and im about to add the rubber ones as well. Good to have options. Thanks
Re: High performance engines and pcv systems [Re: justinp61] #2508451
06/14/18 03:47 PM
06/14/18 03:47 PM
Mt Morris Michigan
Mt Morris Michigan
What style breathers you using?
Re: High performance engines and pcv systems [Re: Thumperdart] #2508455
06/14/18 03:57 PM
06/14/18 03:57 PM
Mt Morris Michigan
Mt Morris Michigan
I remember. Im also looking at running pvc on one side and double elevated breathers side by side on the other cover. Plenty of flow thru with that too. See if i can post a pic later.
Re: High performance engines and pcv systems [Re: mopar dave] #2508473
06/14/18 04:55 PM
06/14/18 04:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave I honestly don't know, they were on the valve covers when I bought the engine. They are aluminum and had fittings in them for a header e-vac system. Sorry.
Page 1 of 3 1 2 3
