Re: Brass Hammer for Power Steering Pump Pulley Reinstall
[Re: GregY]
#2508192
06/13/18 11:26 PM
06/13/18 11:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You'd be better off boiling the pulley and pushing it on by hand.
You beat on it with a hammer and you'll end up with a messed up pump eventually.
[Re: gtx6970]
#2508310
06/14/18 10:38 AM
06/14/18 10:38 AM
Supercuda
About to go away
About to go away
up yours
There is no 'press on ' power steering pump that I'm aware of. it either has a threaded hole in the shaft for a pulley installer That installer presses the pulley on the shaft. Said installer is essentially a nut and bolt and back when I worked parts it usually came with a reman P/S pump. Go rent the tool f0r free from autozone https://www.autozone.com/loan-a-tools/po...er-kit/2075_0_0
[Re: Supercuda]
#2508312
06/14/18 10:42 AM
06/14/18 10:42 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
There is no 'press on ' power steering pump that I'm aware of. it either has a threaded hole in the shaft for a pulley installer That installer presses the pulley on the shaft. Said installer is essentially a nut and bolt and back when I worked parts it usually came with a reman P/S pump. Go rent the tool f0r free from autozone https://www.autozone.com/loan-a-tools/po...er-kit/2075_0_0 Pretty sure what he meant was you don't use a press to install it. Yes, the install tool "presses" the pulley on, but using a press can damage the pump from putting pressure on the backside of it.
[Re: an8sec70cuda]
#2508316
06/14/18 10:52 AM
06/14/18 10:52 AM
Supercuda
About to go away
About to go away
up yours
Yes, I know bu tit is obvious the OP doesn't and clarification was needed.
[Re: GregY]
#2508609
06/14/18 11:07 PM
06/14/18 11:07 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I do have the factory service manual as a reference also. Read, use, and follow it
