Brass Hammer for Power Steering Pump Pulley Reinstall #2508180
06/13/18 11:14 PM
06/13/18 11:14 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Guys,
I am going to be working on rebuilding my power steering pump this summer and I understand part of that process involves reinstalling the pulley with a brass hammer.
My questions is, for that process, do I need a 2 lb brass hammer, or is an 8 oz. hammer sufficient?
Thanks.
Greg
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508184
06/13/18 11:21 PM
06/13/18 11:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Brass hammer? If it's a press on and there's no bolt thread in the center of the pulley shaft they are usually pressed on to the pump input shaft before the rest of the pump guts are installed and the resevoir can goes on. A brass hammer may break something.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: Sixpak] #2508188
06/13/18 11:23 PM
06/13/18 11:23 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
A press would be better, but I don't have one. I have heard of doing it with a brass hammer, any real world advice or experience with that?
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508192
06/13/18 11:26 PM
06/13/18 11:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You'd be better off boiling the pulley and pushing it on by hand.
You beat on it with a hammer and you'll end up with a messed up pump eventually.
Don't be the exception.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508194
06/13/18 11:27 PM
06/13/18 11:27 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I'd use a bench vise as a press and a little heat on the pulley center before I tried to put it together with a hammer, same as you might pressing u joints or upper control arm bushings in or out. Years ago I screwed up a perfectly good TRW pump by trying to hammer the pulley back on. Cracked part of the casting...
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: Sixpak] #2508208
06/13/18 11:56 PM
06/13/18 11:56 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
This is the kind of good advice I need, thank you.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508258
06/14/18 04:52 AM
06/14/18 04:52 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
If the shaft has a threaded hole on end; there's a very cheap/simple pulley install kit avaliable at most auto stores. It has an arbor for starting it straight on shaft. It usually will work for various other makes of pulleys.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508287
06/14/18 09:57 AM
06/14/18 09:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
There is no 'press on ' power steering pump that I'm aware of.
it either has a threaded hole in the shaft for a pulley installer /
or has a key slot on it where the pulley simply slides over it and is held in place with a nut
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: gtx6970] #2508304
06/14/18 10:26 AM
06/14/18 10:26 AM
GMP440 Offline
GMP440  Offline
Should not even need to be pressed on. Put it on by hand and the bolt and your done.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: gtx6970] #2508310
06/14/18 10:38 AM
06/14/18 10:38 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That installer presses the pulley on the shaft.
Said installer is essentially a nut and bolt and back when I worked parts it usually came with a reman P/S pump.
Go rent the tool f0r free from autozone
https://www.autozone.com/loan-a-tools/po...er-kit/2075_0_0
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: Supercuda] #2508312
06/14/18 10:42 AM
06/14/18 10:42 AM
an8sec70cuda Offline
Pretty sure what he meant was you don't use a press to install it. Yes, the install tool "presses" the pulley on, but using a press can damage the pump from putting pressure on the backside of it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: an8sec70cuda] #2508316
06/14/18 10:52 AM
06/14/18 10:52 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, I know bu tit is obvious the OP doesn't and clarification was needed.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: Supercuda] #2508384
06/14/18 01:51 PM
06/14/18 01:51 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Thanks everyone. I will have to look for the reference I was looking at that gave me the impression that it needed to be pressed back on.
I am trying to get all my ducks in a row before I start and not when I am in the middle of it.
Greg
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508393
06/14/18 02:04 PM
06/14/18 02:04 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
How about a piece of hickory and a hammer? Worked for me.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508454
06/14/18 03:51 PM
06/14/18 03:51 PM
VA
dragon slayer Offline
VA
You have not said what pump you are working on, but if a TRW or Federal and you try to press it on, you will unseat the pump, and it will not prime.
The pulley is pulled on with a threaded screw and rotating washer/bearing. It is pulled off with a simple pulley tool. All the work/forces are on the shaft, not the whole assembly. Read the Service Manual.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: dragon slayer] #2508518
06/14/18 06:52 PM
06/14/18 06:52 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
It is a Sanginaw pump. I do have the factory service manual as a reference also.
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2508609
06/14/18 11:07 PM
06/14/18 11:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
Read, use, and follow it up
Re: Brass Hammer for Power Steering Pump Pulley Reinstall [Re: GregY] #2509100
06/15/18 09:17 PM
06/15/18 09:17 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
For pulleys like this I heat them up by placing them on a 100 watt light bulb.
Only takes 10 minuets.
You will have to use gloves to pick it up and place on the shaft.
Works for alternator pulleys.
