Re: Need more towing power 1995 5.9 magnum [Re: basketcase] #2505071
06/06/18 02:31 AM
06/06/18 02:31 AM
Az
69hemibeep Offline OP
Az
Originally Posted By basketcase
told ya it had a button......
But you described a power glide above with L and D wink
1969 Hemi Roadrunner 2nd owner
Re: Need more towing power 1995 5.9 magnum [Re: 69hemibeep] #2505126
06/06/18 10:47 AM
06/06/18 10:47 AM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
don't you have a phone to fix?
1981 Dodge D150 360 auto
Re: Need more towing power 1995 5.9 magnum [Re: 69hemibeep] #2505131
06/06/18 10:58 AM
06/06/18 10:58 AM
Az
Az
Nobody uses them any more LOL
Re: Need more towing power 1995 5.9 magnum [Re: 69hemibeep] #2505245
06/06/18 02:49 PM
06/06/18 02:49 PM
east side of Ohio
east side of Ohio
that;s cause they're waiting for the repairman to show up
Re: Need more towing power 1995 5.9 magnum [Re: DaytonaTurbo] #2505269
06/06/18 03:37 PM
06/06/18 03:37 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Originally Posted By DaytonaTurbo
IMO the automatic transmission is working against you more than the engine power. At least with a stick the driver can keep it in gear instead of downshifting constantly the way these trucks like to.
On my automatic trucks of that vintage I like to pull the part throttle kickdown valve body add on thingy off and throw it in the trash and put a block off plate on the VB. It only changes 1-2 and 2-3 shifts but it helps reduce the number of shifts at lower speeds. If you don't throw it in the trash you can use it on older cars with big cams to help keep them in their usefull power band.
Another thing I like to do is block the OD acumulator in the VB, the spring is usually broken anyhow, just pull the piston (no VB removal needed) throw away the spring and fashion a blocker from a wooden dowl to keep the piston from moving at all when the cover plate is added back.
Re: Need more towing power 1995 5.9 magnum [Re: Guitar Jones] #2508164
06/13/18 10:40 PM
06/13/18 10:40 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
It idles fine after the computer learns it. At first it would die and not idle properly but it learned quick. The only issue is any time the battery is disconnected or goes dead the computer has to go through the learning process again. Not a big deal at all really.
