Re: High performance engines and pcv systems
[Re: ahy]
#2508162
06/13/18 10:39 PM
06/13/18 10:39 PM
Posts: 4,681 Wichita
GY3
Wichita
Yep, I do the PCV valve on passenger cover and a K&N open breather modded to fit the stand on the drivers side cover.
I've used cheap, chrome Mr. Gasket breathers in the past and they simply can't flow enough air at higher rpm. Years ago my dipstick would blow out of the tube because of crankcase pressure buildup with one after 4.56 gear install..
[Re: mopar dave]
#2508227
06/14/18 01:10 AM
06/14/18 01:10 AM
Posts: 4,206 New York
polyspheric
New York
The clean air intake and PCV to the manifold should be separated by the entire engine if possible to pass all the crankcase vapor through them. If they're both on one cover the case is never "flushed" and accumulates sulfuric acid and combustion products. Severe blowby is generally ring seal going away, and you already know what fixes that. A much bigger pan volume (longer, deeper, wider), for more air not more oil, reduces the amplitude of pressure spikes, so will any extension to the valley or covers. It's only a buffer, so shape doesn't matter as long as the connection to the air under the crank is large.
Boffin Emeritus
[Re: Spaceman Spiff]
#2508291
06/14/18 10:07 AM
06/14/18 10:07 AM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
My PCV valve is a Billet style from billet specialties. Too much oil in the pan is not helping either. I will be installing an oil cooler this weekend, that will get the oil level back down. I also have an oil catch can im not using that i could install or use the tall breathers that Andy posted. Moroso also has something simular.
[Re: mopar dave]
#2508297
06/14/18 10:22 AM
06/14/18 10:22 AM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
Pictured below is my wedge motor in my other car. Two -10 lines tee'd into a breather tank mounted next to the radiator. Works great. I have a vacuum pump on my hemi, but honestly, I wish I'd just done the same thing on it.
[Re: mopar dave]
#2508370
06/14/18 01:31 PM
06/14/18 01:31 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Maybe thats part of my problem. 8qts in a 7qt pan. BIG problem try the opposite, less oil in a larger capacity pan and I run 6 qts. in an 8 qt. pan and zero issues forever........As we talked, my pcv is in a Ford truck breather full of foam which is higher up off of the valve cover helping to keep oil out of the manifold and more vapor as designed plus a home made oil separator right at the manifold............ Breather on one side, pcv on the other to pull THROUGH the engine......
[Re: mopar dave]
#2508473
06/14/18 04:55 PM
06/14/18 04:55 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
What style breathers you using? Dave I honestly don't know, they were on the valve covers when I bought the engine. They are aluminum and had fittings in them for a header e-vac system. Sorry.
