2nd gen wont start after heavy rain #2507767
06/13/18 01:05 AM
06/13/18 01:05 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Yup,
After it rains and the truck sits, it cranks fine but will not start.
Most of the parts have been replaced, crank sensor, coil, cap rotor, even tried a computer swap.. No go.
Typically after the weather dries up, it is perfect again..
Not ready to move to AZ, anyone had the same problem> truck is 2001 Dodge ram 1500. 5.9 gas
Re: 2nd gen wont start after heavy rain [Re: sthemi] #2507978
06/13/18 03:44 PM
06/13/18 03:44 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Replaced or test the igntiion wires also?
Sometimes will see the arc from lousy wires on a wet night.
Otherwise, I'd be looking for a bad connection or splice in the wiring harness. A OBD II scanner (not just a code reader) may help alot to track down the faulty circuit
Re: 2nd gen wont start after heavy rain [Re: sthemi] #2508039
06/13/18 05:51 PM
06/13/18 05:51 PM
P
Paul_Fancsali Offline
P
Change the coil bet it has rust on bottom of it
Re: 2nd gen wont start after heavy rain [Re: Paul_Fancsali] #2508245
06/14/18 03:24 AM
06/14/18 03:24 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the comments and ideas, both the coil and spark plug wires have be replaced trying to figure this out.
Probably going to change the cam sensor next to see if that helps..
Possibly the wire loom has some hidden damage.
Of course it is dry today and it started like nothing was wrong.. never any codes to read on this either.
Re: 2nd gen wont start after heavy rain [Re: sthemi] #2508791
06/15/18 11:07 AM
06/15/18 11:07 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Well, if it's dry out, how 'bout filling a spray bottle that can spray a fine mist, divide your engine compartment into quarters, and spray them one at a time to see if you can figure out which quadrant is giving you fits. Then you can narrow it down to stuff in that area of the engine bay. I'm assuming the problem isn't in the cab...
Re: 2nd gen wont start after heavy rain [Re: sthemi] #2508804
06/15/18 11:25 AM
06/15/18 11:25 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Considering what parts you have changed,
and since you do not list replacing the ignition wires,
I would suspect the long coil to distributor cap center wire.
First take that wire off and check if you have spark from the coil HV terminal to ground while cranking.
I now check ignition wires by wrapping aluminum foil around the outside and then using an old crank Biddle Mega-ohmeter using the 1000 volt output.
If you do not own or could borrow a Mega-ohmeter
I would remove the Magnum coil to cap wire from your Ram
and install it on one cylinder of another vehicle with a known good ignition system.
Start that vehicle and run a grounded wire probe up and down the insulation of suspect wire looking for sparks and listening for missfires on that cylinder.
Re: 2nd gen wont start after heavy rain [Re: 360view] #2508949
06/15/18 03:16 PM
06/15/18 03:16 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Happened to a buddy of mine at work one day. After he changed the spark plugs and wires it fired right up and started fine after every rain after that. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: 2nd gen wont start after heavy rain [Re: sthemi] #2509188
06/16/18 12:37 AM
06/16/18 12:37 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
bulk head connector....
Re: 2nd gen wont start after heavy rain [Re: savoy64] #2510231
06/19/18 12:17 AM
06/19/18 12:17 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...is under the dash out of the weather.
Re: 2nd gen wont start after heavy rain [Re: J_BODY] #2510282
06/19/18 05:17 AM
06/19/18 05:17 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks to all for the great ideas, ..
it has been way to hot ( and dry) to work on this..and of course it is running fine...
