Solid u-joint part # #2507221
06/11/18 08:05 PM
06/11/18 08:05 PM
pennsylvania
poboyengineering Offline OP
pennsylvania
What solid joint is everyone running?
I just don't trust the hollow ones.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Solid u-joint part # [Re: poboyengineering] #2507228
06/11/18 08:23 PM
06/11/18 08:23 PM
Locomotion Offline
Locomotion  Offline
I don't have any part #'s handy, but my opinion is that Spicer solid joints are the best. A billet steel rear end yoke with u-bolts is good insurance as well since the forged style can spread over time.
Re: Solid u-joint part # [Re: poboyengineering] #2507231
06/11/18 08:40 PM
06/11/18 08:40 PM
pennsylvania
pennsylvania
I will update to the big joint and a better yoke when I have the funds to get a new driveshaft. Until then, the forged stuff will have to do. I feel I'm safe with a NA footbrake small block.
Re: Solid u-joint part # [Re: Locomotion] #2507344
06/12/18 12:09 AM
06/12/18 12:09 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
100%
'63 Dodge 330
11.19 @ 121 mph
Re: Solid u-joint part # [Re: poboyengineering] #2507385
06/12/18 01:56 AM
06/12/18 01:56 AM
Which series u joints are you running now, 7260(small),7290(big) or 1330 (Stock hemi Dana 60 joint)?
I have several Neapco HD 4x4 truck U joints in stock so maybe I can provide you a part # luck
Re: Solid u-joint part # [Re: poboyengineering] #2507507
06/12/18 01:13 PM
06/12/18 01:13 PM
pennsylvania
pennsylvania
3.5" wide by 1 1/16" caps. I'm thinking these are the small joints.
Re: Solid u-joint part # [Re: poboyengineering] #2507531
06/12/18 02:43 PM
06/12/18 02:43 PM
Canada
RobR Offline
RobR  Offline
Canada
Should be a Spicer 5-1350-1X ...3.625 outside to outside with a 1.188 cup
Re: Solid u-joint part # [Re: poboyengineering] #2508116
06/13/18 08:40 PM
06/13/18 08:40 PM
pennsylvania
pennsylvania
That gives me a starting point, but I need the inside c-clips. No, I don't know what this shaft came out of, just that it's the right length.
Re: Solid u-joint part # [Re: poboyengineering] #2508904
06/15/18 02:15 PM
06/15/18 02:15 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Spicer Life Series U-joints(solid body)
7260 1.078cap (Small Mopar) = 5-789x
7290 1.125cap (Big Mopar) = 5-811x
1350 1.188cap 3.625oa outside snap ring = 5-1350x
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
