Re: Jim Santo. 727jim
[Re: J_BODY]
#2506518
06/10/18 11:16 AM
06/10/18 11:16 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Griner has been out of the Torqueflite biz for sometime I understand. Kevin (727Specialist) worked with Griner too iirc His name is Keith from 727 Specialist.
[Re: Sammy]
#2506798
06/10/18 10:06 PM
06/10/18 10:06 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
Griner has been out of the Torqueflite biz for sometime I understand. Kevin (727Specialist) worked with Griner too iirc His name is Keith from 727 Specialist. Thanks for the correction!
[Re: mopar dave]
#2506811
06/10/18 10:44 PM
06/10/18 10:44 PM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
I have been in contact with Keith. The only Griners he has go into his transmissions. Hotch has 2 left but are spoken for. More than likely will get an A&A. Does ATI make their own valve body for 727? Cant help but ask when you yourself said the car was built to be 99% street driven why you are so concerned about a trans brake? That said, i used to have a Griner brake on my blue Duster. I took out a thrust while it was in the car. The guy i sold the car to told me his tranny guy stated the very high line pressure that brake likes was the cause of taking out the thrust bearing. I dont have enough knowledge to know, just relaying what i heard. Know a lot of guys using the A&A brake, certainly think its a good unit, love how mine shifts. Wont be using the brake function just yet. Btw, i saw ZERO difference in ET’s or 60 foots with the blue car off the foot or the brake. If i had a predominately street car, doubt i would bother with a brake. Very little benefit unless pro tree racing or bracket racing aid perhaps. But they can brake stuff
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2507280
06/11/18 10:23 PM
06/11/18 10:23 PM
dartman366
Mt. Vernon, Ohio
I have never said i wanted a brake. Again, what i'm looking for is a Griner RMVB no brake. I had an A&A brake with the small block. Tired of pushing the button to back up. put a toggle switch on it to activate reverse that's what I am going to do with my Cope pro brake VB to help maneuver around the pit's, I know someone on the board here has a schematic for wiring it in.
[Re: mopar dave]
#2507299
06/11/18 10:51 PM
06/11/18 10:51 PM
B3422W5
Portage,michigan
I put my button on a stretch cord and just let it lay on the floor. To back the car up i just pick it up and place it wherever i want it to facilitate backing up. Makes it super easy. Can hold cord on the wheel or wherever i want it, to make backing up comfortable.
