Considering Myself Lucky
#2507291
06/11/18 10:40 PM
06/11/18 10:40 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Went to Lebanon Valley for their first index race. Ran 10.0 class and stumbled my way to the final (light turnout). Launched great, when I shifted to 3rd...bang Was having trouble launching on the 2 step. I finally realized in the semi final, it was not working, so I was launching on the upper rev limiter (7200 instead of 4400)...Hard of hearing The splined hub remained on the input shaft, sheared all of the rivets. You will note that there is no section of the disc missing, the slots just closed up I haven't found any other damage yet.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Considering Myself Lucky
[Re: oldiron]
#2507303
06/11/18 10:57 PM
06/11/18 10:57 PM
Posts: 4,457 Washington
madscientist
Washington
That's not good. It would be nice to know whose disc it is. Maybe they had a bad run or something.
That's the last thing I need to happen.
[Re: madscientist]
#2507309
06/11/18 11:13 PM
06/11/18 11:13 PM
oldiron
New Hampshire, USA
It is a McLeod. But I'm pretty sure that they are all made by the same company. I looked back at old discs and they all have cracks starting, The cracks start at the keyhole at the slots and then start migrating. I started bevelling the holes to see if it would help. I guess not. But this was a well abused disc. The 7000 rpm launch didn't help
[Re: oldiron]
#2507368
06/12/18 01:26 AM
06/12/18 01:26 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have had that happen, sheared the rivets right off. I just replaces the disc thinking everything was good. After assembly I found there was a vibration that I couldn't find. Finally pulled the clutch assembly back out and noticed the pressure plate clamping face was off center. Looking at the pressure plate I found that one of the 3 torque bars was bent, pulling the plate off center. These are the multi stacked plates that are riveted to the top cover plate holding everything together. Doing research with the clutch manufacturer they stated the shearing of the rivets released the torque on the system causing the bar to bend. I don't know if thats what caused my problem but replacing the pressure plate solved the vibration .
[Re: oldiron]
#2507393
06/12/18 02:19 AM
06/12/18 02:19 AM
rowin4
One thing about racing a stick shift car you find the weakest link over and over till you get it right. Haven't broke a u-joint in years but I broke the dana 60 twice.
[Re: 1Fast340]
#2507593
06/12/18 05:48 PM
06/12/18 05:48 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Yikes! !!
That could have gone bad quickly. I imagine the whole driveline took a beating.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: oldiron]
#2507603
06/12/18 06:09 PM
06/12/18 06:09 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Whow, that sux...I'm glad you and the car are okay though. Parts can be replaced.. C U soon.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68shifter]
#2507638
06/12/18 07:24 PM
06/12/18 07:24 PM
oldiron
New Hampshire, USA
There was no other damage. The disc just started to touch the PP hat, but is ok. It's lucky that the hub let loose when it did, and the section of disc did not let loose. The moral of the story is: look at the disc closely from time to time. I think. New disc coming! Hope to be back at it soon. Will cu in not too long.
[Re: oldiron]
#2507832
06/13/18 09:59 AM
06/13/18 09:59 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Dang, that could have been ugly. When I first built my Duster I built it as a four speed. It never made a full pass with the stick in it despite spending about 4 times as much money on it as a really nice auto and converter would have cost. Put the 904 in it and except for converter hubs cracking I never had another driveline failure.
[Re: oldiron]
#2508140
06/13/18 09:56 PM
06/13/18 09:56 PM
dartman366
Mt. Vernon, Ohio
There was no other damage. The disc just started to touch the PP hat, but is ok. It's lucky that the hub let loose when it did, and the section of disc did not let loose. The moral of the story is: look at the disc closely from time to time. I think. New disc coming! Hope to be back at it soon. Will cu in not too long. I would also say you need to buy a lottery ticket, glad to see it all stayed together enough to keep from picking up chunks off the track.
