Solid u-joint part #
#2507221
06/11/18 08:05 PM
06/11/18 08:05 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
What solid joint is everyone running? I just don't trust the hollow ones.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Solid u-joint part #
[Re: poboyengineering]
#2507231
06/11/18 08:40 PM
06/11/18 08:40 PM
poboyengineering
pennsylvania
I will update to the big joint and a better yoke when I have the funds to get a new driveshaft. Until then, the forged stuff will have to do. I feel I'm safe with a NA footbrake small block.
[Re: Locomotion]
#2507344
06/12/18 12:09 AM
06/12/18 12:09 AM
Posts: 4,704 Wichita
GY3
Wichita
I don't have any part #'s handy, but my opinion is that Spicer solid joints are the best. A billet steel rear end yoke with u-bolts is good insurance as well since the forged style can spread over time. 100%
#2507385
06/12/18 01:56 AM
06/12/18 01:56 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Which series u joints are you running now, 7260(small),7290(big) or 1330 (Stock hemi Dana 60 joint)? I have several Neapco HD 4x4 truck U joints in stock so maybe I can provide you a part # ![luck luck](/ubbthreads/images/graemlins/custom/luck.gif)
#2507507
06/12/18 01:13 PM
06/12/18 01:13 PM
poboyengineering
pennsylvania
3.5" wide by 1 1/16" caps. I'm thinking these are the small joints.
#2508116
06/13/18 08:40 PM
06/13/18 08:40 PM
poboyengineering
pennsylvania
That gives me a starting point, but I need the inside c-clips. No, I don't know what this shaft came out of, just that it's the right length.
