Re: Paint job on a budget!? CONTINUED..page 44........
#25059
07/13/06 07:35 PM
07/13/06 07:35 PM
look for this container at an automotive paint store. its a blue container and made esp. for your situation and its almost like clear white inside. white cap , white writings..lol sorry dont know the brand name. also bulldog works too. just scuff it. as for rustoleum and tremclad being the same..i always new it was different but simmiliar...when someone showed their miata finishing job, i mentioned it was tremclad that he painted it with and not rustoleum...anyhow, im buffing the car today, i should have pics tonight!
[Re: texczech]
#25062
07/14/06 11:43 AM
07/14/06 11:43 AM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
If we are talking about the Brightside paint... if you are doing the 'roll and tip' method to remove the bubbles... it should be done very soon after the layer of paint is put on. This gives the popped bubble the maximum chance to merge in with the paint and become self leveled. If you wait tooo long... the paint and the bubble will have started to get 'tacky' and the movement of the brush over a tacky surface would just create extra work for you sanding the surface. One thing I noticed about the Brightside paint is that it is possible to treat it just like Rustoleum/Tremclad.. in that you can add extra 'brushing fluid' ( Interlux product number 333 ). You can basically wet the Brightside paint to as thin as the Tremclad paint. When the paint is thinned to this consistency it paints on thinner... but the bubbles have a tendency to self-pop just like the diluted Tremclad. The only problem with using highly diluted Brightside is that it will obviously take more coats to get full coverage... and you will need to revert to just straight uncut Brightside for the final layer in order to get the maximum shine and gloss on that final layer. ( Highly thinned Brightside doesn't produce anything near the high gloss of the unthinned product ). Now... if you were talking about using the roll and tip with the Tremclad/Rustoleum paint the same rules probably apply. It is best to pass the magic brush over the bubbles as soon after applying the paint. Since the coating of Tremclad/Rustoleum is pretty thin it should only take a very light passing of the brush. I have been doing some additional reading about the 'roll and tip' method used by boater and the 'very best' results that they obtain seem to be one of the following two methods : a ) use your one favorite 4" china bristle paint brush... and between each panel put it in the mineral spirit or thinning fluid to clean the brush... or b ) if you are using the disposable foam brushes... try to use three brushes... one for each side of the car and one for the hood and trunk. The biggest problem the boaters find with the 'roll and tip' is that the 'tipping brush' tends to load up with paint. If you are only using one tipping brush and if it takes about one hour to completely walk around the car rolling and tipping... then the paint on the 'tipping brush' could conceivably be up to one hour old on the brush by the time you hit the last panel. So by using a number of fresh brushes OR keeping your one good brush constantly cleaned between doing panels you can avoid the problem of 'paint build up' on the brush having an adverse effect on the effective smoothing of the coating you are popping bubbles on. It all sounds so logical but it was hard to hunt down that little secret involving the 'roll and tip' method. I don't know if that is because the practitioners of the 'roll and tip' assume that everyone knows that... or if it is really a secret of the folks who take their 'roll and tip' methods seriously and don't like giving away their little trade secrets .
[Re: Marq]
#25063
07/14/06 01:51 PM
07/14/06 01:51 PM
Hello all, I have been a lurker since page 20 of the first thread and I am finally ready to paint.
Thank you very much Marq for trying and explaining how to use the boat paint. Please keep the pictures coming, the mustang convinced me to try it.
I have an orange 1970 porsche 914 that was repainted before I got it. Totally orange peeled and scratched. I have ordered some orange boat paint from epifane (20 bucks for 750ml) and will attempt this technique on my rear trunk lid to begin with. That company is the only one I could find that makes orange in a one-part eurathane.
My plan is to hit the old paint with a degreaser, wetsand with 320, then 400, then first coat of epifane with just a splash of thinner (mineral spirits according to the company), roll and tip, then sand with 600 once dry, then another coat very slightly thinned epifane, sand with 800, then 1000, then a final full strength coat of orange. In between each step I will wipe the lid with mineral spirits to clean it off.
I am a little concerned with the working time of the paint, which is why I plan on thinning it just only slightly. That should extend the working time, shouldnt it? I figure I need 15 minutes from rolling to tipping, and I dont want the paint to get too tacky in that time frame. Im working in Berkeley where the humidy is very low and the temp should be 65-75.
I will post pics when I am done.
Thanks to everyone who has contributed to this thread!
[Re: Marq]
#25064
07/14/06 10:54 PM
07/14/06 10:54 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
Things are looking awsome!!! no pics tonight, but I will have some tomorrow. 8th coat on the truck box, and 5 on the hood now. The metallic in between layers works excellent!! All that's needed is just a dusting of metallic paint, to adhere some of the sparkle to the surface, and then lay the next coat right over it. So far, i've had absolutely no problem with orange peel or runs. Like Krylon put it at one point, No runs, no drips, no errors I'm getting fidgety waiting to put the final polish on it. Just a note on the wet sanding, I've found that 800 is the best grit to start with, simply because I'm a touch too aggressive with 400 I tri-fold the sheet, and wrap it around an ordinary kitchen sponge, then only sand until the drag of the paint is gone, and the paper glides across the surface. Seems to work good for me, so far Amazing results as far as I can see at this point. A month ago, before reading this post and seeing the results others have had, I would have said it was impossible to do. ( maintenance tech with lots of industrial painting experience, grab the can and brush and slap at the machine as fast and thick as possible ) Keep up the fantastic work, guys, it's worth the effort in my opinion. BTW, FarFire, you should really be impressed with the Hunter Green, it looks awesome when the layers add up.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
#25065
07/14/06 11:50 PM
07/14/06 11:50 PM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Tee hee... you could have taken the Brightside Fire Red and the Safety Yellow... combined them and created you own custom mix orange You could have experimented with your mix of red and yellow and come up with just about any variation of orange that might be flattering on your car.
The only caution I would throw at your plan is the 'wiping between steps with mineral spirits. You should have said " I will wipe between sandings using WHATEVER THINNER is recommended by that paint manufacturer.
I mention that because 'if' your paint uses Ketone or Acetone as the thinner... and you use mineral spirit as the 'wipe down' fluid... there is always a chance of a reaction between your paint and the mineral spirit. Something between an orange peel and wrinkling ( elephant skin) ...
So by using 'whatever' fluid is recommended for thinning by your paint manufacturer you will cut down on the 'chance' that there 'might' be a compatibility problem.
For example, Brightside uses Ketone ( which they package and sale as their product number 333 Brushing and Thinning fluid. Although it 'appears' that I could thin Brightside with mineral spirits... I have stuck with the thinner actually mentioned by Brightside.
One nice sand paper that does a wonderous job at ripping down the original botched up paint is the 220 grit 3X sand paper. You can get it at Home Depot and the packaging says that it last 3 times longer than normal sand paper. It cost a bit more.. but it really is worth the few extra bucks. The second you open the package you will feel the difference between the 3x paper and regular stuff. The 3X feels almost like it is linel paper ( sort of like the paper they use for money )...
The only other thing I would like you to consider is the use of a PRIMER at the start of your work. You might want to use a white primer if you want a bright and light orange color... or maybe use a darker colored primer to end up with a darker orange when all the coatins have been added. I am so impressed by how well the Interlux Precote primer worked on my test piece and I can say that the few bucks you may spend on putting down a good uniform color via a primer may end up saving you work, time and paint in the long run. Consider it... cuz I don't think you will regret it.
I can't speak for the brand of paint that you have chosen and I don't know much about its ability to level, gloss or how long you have to work with it while doing the rolling and tipping.
In theory though... thinning the paint 'should' give you more time to work on the paint before it starts to become tacky. Cooler temperatures are also a big plus at giving you more 'working time' on the paint before it starts getting tacky.
High humidity is another factor that fits into this... in that the higher the humidity... the less gloss the paint has when it dries. I don't quite know why humidity has an effect on the final gloss... but this has been confirmed in numerous conversations and messages on the boater forum..
[Re: Marq]
#25066
07/15/06 12:42 AM
07/15/06 12:42 AM
thanks marq for the input! The guy at epifane I spoke to assured me the correct thinner for the paint is just regular mineral spirits. I guess I could have mixed the brightside paint colors, and I might try that if I dont like the epifane paint or the color. good point! I was at home depot yesterday and saw the sandpaper you mentioned, I didnt get any, I thought 220 might be too harsh, leave too many scratches, but I will pick some up tomorrow. I also thought about a primer, but my car is already orange and I am painting it a similar color, so I decided to skip it. I found my paint at www.epifanes.com, check it out if you get a chance. Their varnishes seem to get good reviews, but I couldnt find much on the net about their paints. We will see how their paint compares to brightside. My paint should be here monday and I cant wait to give this a shot!
#25067
07/15/06 09:34 AM
07/15/06 09:34 AM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
I took a look over at the Epithanes web site... and I am confused.. a ) the monoeurethane doesn't come in orange... the mono is their 'one part' eurathane... b ) the polyurethane paint that does come in orange is a 'two part' paint. Based on what I saw on their web site, I believe you have purchased a 'two part' polyurethane... All I know about the 'two part' paints is that their fumes are far more wilder ( dangerous to humans ) than the fumes given off by the 'one part' paints. The one part paints take a little longer to cure ( more working time ) because they don't have an accelerant/catalyst. The two part dries faster because the fumes are evaporating quicker and in a higher concentration then the one part paint. It's sort of like a reverse situation of the mineral spirits... where the 'odorless' mineral spirit doesn't evaporate as quickly and hence gives off lower concentrations of fumes... and the 'regular' mineral spirits evaporate more quickly. On the topic of the one part paint systems and the two part paint systems.. Brightside is a one part urethane. No mixing and you use it straight out of the can... But Interlux also makes a 'two part' eurathane called 'Perfection' - which although it had better hardening qualities and shine qualities I avoided because of all the warnings about the two part fumes. If your can of paint arrives on Monday... just see if there is one can or two... if there is a second smaller can... that is the accelerant/catalyst for the 'two part' paint system. Another thought is that the 'two part' paint system may have a different 'working time' once you apply it because the catalyst will be yet another factor in the time the paint stays workable etc. My last thouoght on this paint... is that the company sounds quite excellent BUT the one thing that gave me a pause was where they mention their 100 year proud history and heritage.... My first thought after reading how long that company has been around is that I have not seen their name come up in any of the discussions on the boater web sites when discussing paint for the upper sections of boats... It just struck me as odd that a company that has been around that long 'would get some folks talking about it' Instead, all the discussions on the boater boards centers around AWlgrip, Petit and the paints by Interlux ( Brightside & Perfection ). Dunno... just thought I would pass along those thoughts... Oh... an as for that 220 grit Triple X ( last three times longer ) sand paper.. I was quite surprised what a decent job it did on my my sanding. I didn't get any scratches or swirls using it. It is agressive - but not so agressive that you can't control the agression by just using lighter pressure on your sander. What I particularly liked about that sand paper was the way if kept relatively clean while sanding. It seems better at evacuating the sandedd particles out from under the sander and it doesn't seem to clog up with the debris. I think the reason why it produces a fairly smooth surface without any artifacts is the abrasive material they are using and the way in which it is applied to the paper. When you look at the sanding surface of the paper you will see the difference in how it has been applied to the paper when compared to 'standard issue' 3M or Norton paper. .
[Re: Marq]
#25068
07/15/06 12:26 PM
07/15/06 12:26 PM
I just returned from my local marine store with some supplies. Two quarts of brightside paint $38.99 each One quart of 333 $14.99 One quart of two part Epoxy primer coat $35.99 total with the goverments cut $147.02 I will need more of both when it comes to the entire paint job {hopefully this Fall} Also talked to the General Manager for a good half hour. I was right up front with him telling him it was for a car he was not supprised at all, brightside has been used for painting cars { spray method } but is not cost efective for an automotive paint business because you need 24 hours between coats . He did recommend I use Interlux perfection { twice the cost per quart}for a guaranteed proven 10 years gloss, Brightside he said was good for 5 to 6 years gloss before it fades I like to brightside colors though.I am sure he is talking about boats there. Now in my case my coupe was meadia blasted and PPG epoxy primmed some time ago and I am still doing sheet metal work on it so I needed a primer that can go over the PPG epoxy primer,bare metal,has filling property's and is sandable that is why I went with Interlux two part epoxy primekote ,if was just going to paint over a existing paint job I would use the pre-Kote. Now I have the stock for my test but it is to dam hot up here now 34 degrees C 40 % humidity. I will hold off for now. Note: The General manager also told me you could get away with only two coats of Brightside. Sorry one more thing before I forget I did talk to him about wet sanding / polishing the final coat he said it is not needed nor has he heard of anyone having to do it with that paint again I and sure he is referring to boats. I was going to do the Tremclad way and still may if this does not work out ,but I am looking a two tone gray scheme I tryed mixing stock tremclad gray with other mixed grays to get the shades I was looking for.It can be done but could not be reproduced should I need at a later date.The bright side Steel Gray and Kingston Gray matchup almost perfectly at least in the color chart. Sorry for the long post. Bryan
[Re: Marq]
#25069
07/15/06 02:02 PM
07/15/06 02:02 PM
I am getting a one-part enamel, but not a urothane. My mistake. As far as I can tell, then paint is similar to rustoleum (which is why it thins with mineral spirits). The guy I spoke to at the company told me the paint isnt quite as durable as the monourothane paint, but I wanted orange. He did say that the paint was very durable, though, and is good for 2-3 years on a boat. If you go to the website, and click on "products", then click on "one-component topside finishes", the paint I ordered was their yacht paint (the green paint in the picture). the monourethane is better paint, but this paint may work also. If not, im only out 20 bucks and a few hours. If so, then great!
Im off to pick up some of that sandpaper, thanks for the tip.
[Re: kenzo42]
#25071
07/15/06 03:00 PM
07/15/06 03:00 PM
Marq, many thanks for your research on the Brightside paint. I put on a coat of the yellow on a door a few days ago, and the coverage, depth and shine is amazing. Additionally, it's pretty much impossible to scratch at all even after just a couple days. Had a tiny amount of orange peel that was really quick to sand out. I will finish up this door and then compare the the Rustoleum body parts -- it looks like I'll be finishing off the entire car with Brightside though, if it's this good.
[Re: C38coupe]
#25075
07/15/06 05:29 PM
07/15/06 05:29 PM
C38coupe There are at least three different types of roll on primer that I know of to date,Transtar 6477,Interlux primekote & MP75 Primer Ultra What I have learned the hard way is that epoxys are very durable but they need to be sealed with filler primer, primer or paint no more than week after application I learned that through another message board.Thats why I need to recover the whole body of my car again before I paint. I plan on roughing up the old epoxy then recoating{number of coats unknown} and sanding. The stuff would be hell to remove 100% {sticks great to metal} I would go for the flat black for sure for a temporary finish.
#25076
07/15/06 08:13 PM
07/15/06 08:13 PM
few pictures..going to take more..
#25077
07/15/06 08:17 PM
07/15/06 08:17 PM
