Cam snout adaptor question for magnum motor #2505817
06/08/18 03:00 AM
06/08/18 03:00 AM
ME
79machocharger Offline OP
ME
Question I ordered the kit from Hughes for the cam snout adaptor but I guess I still need moly coated eccentric for it as well? I’m looking to run a mechanical fuel pump and have a v belt set up
Re: Cam snout adaptor question for magnum motor [Re: 79machocharger] #2505875
06/08/18 11:13 AM
06/08/18 11:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think you can use a stock eccentric, not like you need moly on it.
Don't be the exception.
Re: Cam snout adaptor question for magnum motor [Re: 79machocharger] #2506973
06/11/18 10:56 AM
06/11/18 10:56 AM
scratchnfotraction Offline
I use the Hughes adaptor and a stock eccentric. on a Hughes whiplash roller cam for a magnum in a LA engine. stock LA t cover and fuel pump.
bolts right on no issues. the Teflon coating one is to reduce friction & wear on a race app.
