Best street/strip front brakes
#2505211
06/06/18 01:45 PM
06/06/18 01:45 PM
Posts: 568 Ky
moparmafia
Ky
My son is wanting to race our 68 charger and im looking for the best front brake swap kit for safety. It has 10 inch drums and i was thinking about wilwood or aerospace? Which do u guys prefer and are there any dealers on the board? I want a whole kit so im not chasing parts.Thanks for any help
Re: Best street/strip front brakes
[Re: moparmafia]
#2505219
06/06/18 02:00 PM
06/06/18 02:00 PM
Posts: 4,687 Wichita
GY3
Wichita
My son is wanting to race our 68 charger and im looking for the best front brake swap kit for safety. It has 10 inch drums and i was thinking about wilwood or aerospace? Which do u guys prefer and are there any dealers on the board? I want a whole kit so im not chasing parts.Thanks for any help I use the Wilwoods with the vented (not drilled) brake rotors. It was called the Pro Street kit. They were a bolt on swap onto the drum spindle. Going on 4700 street miles now with hundreds of 1/4 mile passes and zero issues. Mine came with drilled bolts for safety wiring the aluminum hub to the steel rotor. A friend bought the same kit for his Dart recently and said they came with standard bolts? No way I would run them without safety wire!
[Re: moparmafia]
#2505223
06/06/18 02:02 PM
06/06/18 02:02 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I've used two sets of Wilwood front brakes, they work well. Go with the vented, street type rotors for a front application that is street/strip, and be sure and match the capacity of the brake kit to the wieght of the car. Also double check the bore size master cylinder to be used with them. To big, and it will be way too stiff at the pedal and hard to stop.
[Re: moparmafia]
#2505265
06/06/18 03:33 PM
06/06/18 03:33 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
While I'm all about light weight, drag race specific brakes are not usually the best choice for something driven regularly on the street. I would chose Wilwoods over the Aerospace. Replacement parts and brake pad availability need to be considered. And as others have stated, expect to have to make some changes in the rest of the system. A 1.50 or 1.75 bore caliper is going to require more fluid than an .875 bore wheel cylinder.
[Re: moparmafia]
#2505267
06/06/18 03:37 PM
06/06/18 03:37 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I used the 11.75 kit from DR Diff, on my 68 Charger, street strip car,works GREAT !!!
[Re: moparmafia]
#2505317
06/06/18 05:45 PM
06/06/18 05:45 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
When I went with the AlterKation front K member & suspension due to my car still being a street car they recommended Willwood vented but not slotted rotors as mentioned by other above due to the weight of the vehicle still being an all steel street/race car. A lightweight rotor may warp to easy under braking.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: moparmafia]
#2505347
06/06/18 07:01 PM
06/06/18 07:01 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have had wilwood's vented kit on the front of my car for 15 or more years and it has been great. I just added the rear but I haven't driven it yet.
68 Barracuda Formula S 340
[Re: moparmafia]
#2505595
06/07/18 02:00 PM
06/07/18 02:00 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I have Aerospace front HD street/strip disc brake kit on my cuda. Works good, but they can be a PITA to deal with. Took me over a month just to get replacement parts not too long ago.
My next set will be Wilwood.
[Re: moparmafia]
#2506432
06/10/18 12:50 AM
06/10/18 12:50 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My Duster has the 9" drum spindles so my only option was the Strange-Engineering light weight non-vented disc brake kit. I would much rather have a more heavy duty vented setup.
[Re: moparmafia]
#2506561
06/10/18 12:58 PM
06/10/18 12:58 PM
Posts: 4,209 New York
polyspheric
New York
My DD had 11" factory front rotors + 2 piston calipers, replaced with factory 12" rotors + 4 piston calipers. Next step is OEM again, but different brand, instead Z06 (huge!) with adapters: factory quality at the best price. Remember: bigger rotor, caliper, both may need larger wheel diameter and/or different offset.
Heat management (vented, etc.) is only important if you drive the car fast all the time. For any drag use (and street emergencies) you're only going to make 1 hard stop at a time.
Boffin Emeritus
[Re: BigBlockMopar]
#2506837
06/10/18 11:33 PM
06/10/18 11:33 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Wilwood do a dust boot caliper . Australian street requirement
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
