1970 Super Bee braking system change needs
#2504753
06/05/18 11:56 AM
06/05/18 11:56 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
I am changing my 1970 Super Bee V-Code track pack car over from 4 wheel 11" power drum brakes to manual front disc (Kelsey Hays) and 11" rear drums. Can someone please list all of the components I need?
1) I have a pair of spindles, rotors (2 piece) and calipers off of a 1970 B-body. I will rebuild the calipers.
2) I may have a manual brake backing plate for the master cylinder. Does anyone have a picture to confirm? I have the original bendix power booster, plate and linkage, but I am assuming I cannot use any of these pieces.
3) What master cylinder do I get? Obviously I know disc/drum one, but any specific unit? I am putting a Hemi in the car and I know there are engine exit and fender exit master cylinders, which one should I use?
4) Which proportioning / distribution block set up? I want factory looking stuff. Can I use the one I have?
5) I will get a new brake line kit specifically for the set up.
6) What brake rod do I use? Is it a bolt in deal since my pedals were from a power unit?
7) Do I have to change the size of the rear wheel cylinder bore? Did drum brake cars have different ones than disc brake cars?
8) Any other misc info I may have forgotten? I know many people have changes over to disc fronts.....
Thanks,
Jeff
Re: 1970 Super Bee braking system change needs
[Re: Cuda340]
#2504769
06/05/18 12:44 PM
06/05/18 12:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Go here http://www.mymopar.com/index.php?pid=31download the service manual and the parts book. It will answer most of the questions you have and usually has decent pictures of most of the stuff.
[Re: Cuda340]
#2505157
06/06/18 11:56 AM
06/06/18 11:56 AM
Cuda340
Wheatfield, NY
Thanks for the info Supercuda! I do have a copy of the service manual. I just wanted to see if others have already gone down this road and if they had any tips.
Jeff
[Re: Cuda340]
#2506436
06/10/18 12:55 AM
06/10/18 12:55 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Gosh! If you’re going that far swapping to front disks, I would definitely consider going to the 11.75” cop car disks and follow the Mopar Action Magazine “Disc-O-Tech” brake swap article. I did it on my 70 Bee. It incorporates the ‘70 single piston calipers, ‘71 up A body spindles, later B body caliper brackets and factory hoses. I used the Wilwood proportioning valve and defy anyone to detect it. Super well hidden. The Right Stuff makes brake lines with the correct sections to add that valve. Rick Ehrenberg’s article will get you through the master cylinder needs too. I myself went with a later model light weight cylinder as my car is highly customized. https://www.allpar.com/history/mopar/brakes/disc-main.html
I’m listening.
[Re: Big Bad Bee]
#2506979
06/11/18 11:20 AM
06/11/18 11:20 AM
Cuda340
Wheatfield, NY
Gosh! If you’re going that far swapping to front disks, I would definitely consider going to the 11.75” cop car disks and follow the Mopar Action Magazine “Disc-O-Tech” brake swap article. I did it on my 70 Bee. It incorporates the ‘70 single piston calipers, ‘71 up A body spindles, later B body caliper brackets and factory hoses. I used the Wilwood proportioning valve and defy anyone to detect it. Super well hidden. The Right Stuff makes brake lines with the correct sections to add that valve. Rick Ehrenberg’s article will get you through the master cylinder needs too. I myself went with a later model light weight cylinder as my car is highly customized. https://www.allpar.com/history/mopar/brakes/disc-main.html Wow, thanks! Just read the article. I may have to go that route!
[Re: Cuda340]
#2506997
06/11/18 11:48 AM
06/11/18 11:48 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
We use 70 C body disc drum masters.No difference from power as long as the reman has the OE piston to retain the brake rod.Mine has been in for 20 years.Mt kids was in for 15.Rocky
Chrysler Firepower
[Re: Cuda340]
#2507009
06/11/18 12:14 PM
06/11/18 12:14 PM
Posts: 2,920 Calgary, Alberta Canada
a12rag
On my 70 Sport Satellite, it had manual drums, changed to discs up front - still manual, used the lightweight aluminum master cylinder, along with F,M,J body spindles and the larger 11.75" discs and calipers from M body (so they have the bleeder screw in upper spot) . . . no issues at all with this set up and pedal feel is great . . .
[Re: Cuda340]
#2507581
06/12/18 05:18 PM
06/12/18 05:18 PM
Big Bad Bee
Spokane Valley, WA
Would a 1982 Cordoba have the caliper brackets for the 11-3/4 rotor. Pin type? What body platform is that car? You need the '76-79 B body or 79 up R body (first digit of vin is R, W, X or S.) I don't know what the Cordoba is classified as. I got mine of a 4 door St. Regis.
I’m listening.
[Re: gtx6970]
#2507582
06/12/18 05:20 PM
06/12/18 05:20 PM
Big Bad Bee
Spokane Valley, WA
Doesn't the 11.75" rotors require 15" wheels ? Absolutely. Very good point. Cuda340, that will be a deciding factor!
I’m listening.
[Re: 71birdJ68]
#2507583
06/12/18 05:20 PM
06/12/18 05:20 PM
Big Bad Bee
Spokane Valley, WA
Every thing I bought from the Wrong Stuff was, well wrong. Dude, I am sorry to hear that. I bought all mine through summit and it fit like a glove.
I’m listening.
[Re: Cuda340]
#2507610
06/12/18 06:21 PM
06/12/18 06:21 PM
Supercuda
About to go away
About to go away
up yours
F/M/J bodies (80 Doba is a J body) never came with 11.75" rotors, if you find a set on one someone swapped it in, like I did on my old 87 Diplomat.
