2008 3.5 open circuit #5 injector #2504613
06/05/18 12:52 AM
06/05/18 12:52 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
Got a 2008 Chrysler 300 with a 3.5 and high mileage. It runs good but has an intermittent miss and check engine light. I scanned it and the only fault code is an open circuit on the #5 injector. Wiring looks good and I replaced the injector pigtail, replaced plugs just because I was already there and cleared code. It lasted two days and it's back. What do I need to be looking for and how do I check?
Re: 2008 3.5 open circuit #5 injector [Re: AeroMonte] #2504630
06/05/18 01:24 AM
06/05/18 01:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
swap injectors from another cylinder and see if the injector code changes cylinders also. You could go the local parts store and borrow or rent a noid check light.
