Rear main seal question, with engine installed #2504600
06/05/18 12:24 AM
06/05/18 12:24 AM
ILL
Greentween Offline OP
ILL
440 and doing the rear main. Question is can I take off the main bearing cap in front of the seal retainer? I need to clean off RVT from old retainer where it sits in the retainer channel in the block. Main cap blocks access into this area. Especially upper area where the halves meet.
Re: Rear main seal question, with engine installed [Re: Greentween] #2504628
06/05/18 01:21 AM
06/05/18 01:21 AM
The rear main seal retainer needs to be shove backwards with that cap loose enough to allow enough clearance between the rear main cap and the rear main seal holder work scope I would remove it altogether and leave the rear main cap in place instead twocents
