05 5.7 300C engine #2503989
06/03/18 06:34 PM
06/03/18 06:34 PM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
I found a complete, unknown mile 5.7 out of a 300C, beware Newbe questions coming...what are the particulars of this engine, I would like to use it for acstreet/ strip build to go in my 67 Dart, does this have useable heads? Any other specifics that I should know...it is complete less harness and computer, etc...guy wants 1000 for it, came out of a running car. Thanks in advance
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 05 5.7 300C engine [Re: RapidusMaximus] #2503991
06/03/18 06:49 PM
06/03/18 06:49 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
03-08 Hemis have a issue with exhaust seats falling out.. I would get a inspection camera to take a look inside each cylinder. the tensioners on the timing set like to wear out prematurely and improperly maintained hemis tend to spin rods easy, all these items should be looked at and corrected if using the early engines
Re: 05 5.7 300C engine [Re: johnscudashop] #2504005
06/03/18 07:32 PM
06/03/18 07:32 PM
Weatherford, Texas
Weatherford, Texas
My goal would be to build a 600ish hp engine with a 150-250 nitrous shot on demand as necessary so I would definitely be disassembling as upgrading as required.
1968 Plymouth GTX
Re: 05 5.7 300C engine [Re: RapidusMaximus] #2504056
06/03/18 08:59 PM
06/03/18 08:59 PM
USA
hudsonhornet7x Offline
USA
For your goals I would be looking at a known good block first, since you will probably not be using the majority of the internal parts.
$ 1,000 seems steep to throw the most of it away.
Re: 05 5.7 300C engine [Re: hudsonhornet7x] #2504062
06/03/18 09:11 PM
06/03/18 09:11 PM
Weatherford, Texas
Weatherford, Texas
Good info, thanks, that's kinda what I was afraid of, I didn't know if the heads, block and crank would be usable in my application.
1968 Plymouth GTX
Re: 05 5.7 300C engine [Re: RapidusMaximus] #2504067
06/03/18 09:28 PM
06/03/18 09:28 PM
USA
USA
The blocks are good, the heads can be useable but there are better ( cheaper ) options like the " eagle" heads. The crank is cast, etc. The stock rotating assembly with that amount of nitrous is a bad idea in my opinion.
I am glad that Moparts ( Thanks Tom!) gave us our own Gen III forum to learn in. It has been very helpful to me.
Re: 05 5.7 300C engine [Re: RapidusMaximus] #2509954
06/18/18 12:55 PM
06/18/18 12:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Is there a fix for the seats? Staking-peening over?
