Nos 70-2 440 Air Grabber base Ever see this?
#2503610
06/02/18 03:57 PM
06/02/18 03:57 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
I picked up this Nos air grabber 440 base which I am pretty sure is Nos. Just want to make 100% sure. It has the carb bracket spot welded(not stitched) and has the alignment tabs in the throat but they are in the back not like in the front like all the ones I have. I have seen other originals like this. Anyway it never had the drain tubes brazed on which I knew when I bought it. I just wanted to know if anyone else ever saw this and I think this is probably why it became Nos....
Re: Nos 70-2 440 Air Grabber base Ever see this?
[Re: QuickBpBp]
#2503611
06/02/18 03:59 PM
06/02/18 03:59 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
The missing drain tubes Top side and underneath shots...
[Re: QuickBpBp]
#2503653
06/02/18 06:31 PM
06/02/18 06:31 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Thanks. I actually was thinking if ANYONE knew you would! Do you have any left? Guy had this for over 25 years and came out of Lynchburg Virginia and came with an Nos lid.. Do you have a source for the tubes? I know there are lot of auto uses that have tubes like these just wondering if you knew off hand. Figure I can cut off to use if the piece is too long.
