Page 1 of 5 1 2 3 4 5
Inexpensive AN fittings #2503506
06/02/18 10:37 AM
06/02/18 10:37 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Whats the scoop on the latest inexpensive AN fittings im finding on ebay? I can spend $20 for 1 fitting or $20 for 4 fittings. Any harm in using the cheaper fittings?
Re: Inexpensive AN fittings [Re: mopar dave] #2503520
06/02/18 11:24 AM
06/02/18 11:24 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Some fittings are undersized internally, which restricts flow; some are dimensionally inaccurate, which allows leakage.
Seems to follow price-point, in that I've had some problems with Russell fittings and no problems with Earl's. Speedway's fittings have been pretty good, though I've had mixed results with their tube-to-AN compression stuff.
When it comes to flammable liquids or lubricant supply...that stuff's pretty important, and leaks or failure can be catastrophic.
Re: Inexpensive AN fittings [Re: mopar dave] #2503529
06/02/18 11:35 AM
06/02/18 11:35 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've bought stuff off of E bay, from Energy something, don't remember. Anodizing looked super great, but for some reason, all the surfaces were different sizes from what you would normally use. All metric. I found some purple fittings on AliExpress out of China, took 2 months to get my 90's, never got my straight fittings. Can't find anyone that made purple fittings. Will be going back to red/blue or black USA made stuff.
[image][/image]
Re: Inexpensive AN fittings [Re: sgcuda] #2503535
06/02/18 11:47 AM
06/02/18 11:47 AM
Mt Morris Michigan
Mt Morris Michigan
Ok. Looking at XRP and Boostec. Those any good? Using these for my oil cooler set up.
Re: Inexpensive AN fittings [Re: mopar dave] #2503547
06/02/18 12:12 PM
06/02/18 12:12 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I like and use a lot of XRP
"Just a Bracket car dressed up like a streetcar"
Re: Inexpensive AN fittings [Re: Just-a-dart] #2503551
06/02/18 12:25 PM
06/02/18 12:25 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
I'm really poor, but a.n. fitting is something I have yet to try and save money on. Use a good AMERICAN made fitting and you will see the difference I promise you. Its your money spend it as you wish, but I'll always use good fittings. Period.
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Inexpensive AN fittings [Re: mopar dave] #2503555
06/02/18 12:34 PM
06/02/18 12:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
AN, and inexpensive doesn't go together. That is aviation stuff which isn't inexpensive. If it's really cheap, then it probably came from china. The best prices on REAL AN fittings is at Aircraft Spruce, and Specialty
Re: Inexpensive AN fittings [Re: 71birdJ68] #2503568
06/02/18 01:30 PM
06/02/18 01:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
iagree
I always made sure the fittings I used were Hard Anodized. The cheaper fittings are not.
No way I would use china made fittings even on my lawn mower... twocents
Re: Inexpensive AN fittings [Re: mopar dave] #2503573
06/02/18 01:36 PM
06/02/18 01:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
And the obvious question: why do you need them, as opposed to high temperature, 3,000 psi hydraulic hose for 20% of the cost?
And the answer is... SHINY!!!
Boffin Emeritus
Re: Inexpensive AN fittings [Re: mopar dave] #2503583
06/02/18 01:59 PM
06/02/18 01:59 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have used the JEGS brand fittings with no problems.
The Russel fittings are OK, but the ProClasic hose is pretty stiff to get into the fittings. Been told to warm the hose to make it easier to install. Been using the expensive Aeroquip StartLight hose. Pretty easy to assemble.
Re: Inexpensive AN fittings [Re: mopar dave] #2503594
06/02/18 02:36 PM
06/02/18 02:36 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
XRP is top shelf. I've used Aeroquip for years. Everyone has it and being able to get stuff quick matters. Earl's is also fine and they have some odd stuff that no one else has. Never heard of some of this stuff. I don't mix and match manufacturers for hose and ends, and I pay attention to IDs. And of course, the cheap, no name, eBay, off shore trash doesn't come in my door. Seen too much stupid stuff and failures. Not interested in burning a car to the ground over $10. There's a reason it's a quarter of the price.
Re: Inexpensive AN fittings [Re: polyspheric] #2503602
06/02/18 03:07 PM
06/02/18 03:07 PM
Mt Morris Michigan
Mt Morris Michigan
Well, the brass i can get local is shiney too, but i want some color.
Re: Inexpensive AN fittings [Re: CMcAllister] #2503603
06/02/18 03:09 PM
06/02/18 03:09 PM
Mt Morris Michigan
Mt Morris Michigan
I can get XRP for a reasonable price.
Re: Inexpensive AN fittings [Re: mopar dave] #2503606
06/02/18 03:13 PM
06/02/18 03:13 PM
AndyF Offline
AndyF  Offline
I only use Aeroquip for hoses and hose ends but I'll use the Summit brand for adapters and bulkhead fittings.
Re: Inexpensive AN fittings [Re: mopar dave] #2503608
06/02/18 03:28 PM
06/02/18 03:28 PM
tboomer Offline
tboomer  Offline
I used Aeroquip for my fuel lines. I like to save a buck too but I also don't want to cheap out and have my car burn to the ground because of a cheap Chinese fitting made by Uncle Ho and his parts shop. I suppose you will want a Chinese fire extinguisher too?
Re: Inexpensive AN fittings [Re: mopar dave] #2503609
06/02/18 03:54 PM
06/02/18 03:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been real happy with Fragola, if I need something quick the local speedshop has some fragile but mostly aeroquip, I have mixed and matched with no trouble.
68 Barracuda Formula S 340
Re: Inexpensive AN fittings [Re: mopar dave] #2503617
06/02/18 04:25 PM
06/02/18 04:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Buy Earls or any AMERICAN made fittings and enjoy the good stuff instead of the imported crap............... beer
Re: Inexpensive AN fittings [Re: Thumperdart] #2503620
06/02/18 04:38 PM
06/02/18 04:38 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
up It just feels better to put good USA stuff on the car than some cheap junk made by someone who hates you, and wants to cheat you and defeat you.
Re: Inexpensive AN fittings [Re: CMcAllister] #2503625
06/02/18 05:00 PM
06/02/18 05:00 PM
my own world
theraif Offline
theraif  Offline
my own world
stirthepot
Re: Inexpensive AN fittings [Re: theraif] #2503635
06/02/18 05:22 PM
06/02/18 05:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By theraif
stirthepot
There is a lot of truth in the video.
Hey Dom, do you use any Pro-Form stuff? whistling biggrin
BTW, I use Earls fittings and line.
