67 GTX tire size question #2502971
06/01/18 12:19 AM
06/01/18 12:19 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I'd like to know if anyone here might be able to tell me if a 235/70-15 tire mounted on either a 15x6 or 15x7 wheel will fit on the front of a 67 GTX without rubbing. The wheels are Cragars and I believe the 15x7 has 4 1/8 BS. Not sure of the BS on the 15x6.
Re: 67 GTX tire size question [Re: 1970RT] #2502981
06/01/18 12:51 AM
06/01/18 12:51 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
NO they will rub the front corner of the fender. Too tall, the wheel won't matter. Tried it one time.
Re: 67 GTX tire size question [Re: NANKET] #2503065
06/01/18 10:00 AM
06/01/18 10:00 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Thanks. I thought that might be the case but wanted to ask before I started having tires mounted/dismounted to test fit.
Re: 67 GTX tire size question [Re: 1970RT] #2503213
06/01/18 03:32 PM
06/01/18 03:32 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
FWIW I have 28 inch tall tires on the front of my 67, so I don't see why your 235/70 wouldn't work because its too tall. It will be close, and the combination of that tall and wider, I can't guarantee that it will work, but it won't not work because its too tall.
Mine are 670-15 Firestone (coker) tires on 15 x 4.5 Cragars, BS is 2.25 inches. They're supposed to be 28.6 inches tall, I just measured them to be 28 in my garage.
Re: 67 GTX tire size question [Re: 1970RT] #2503223
06/01/18 03:56 PM
06/01/18 03:56 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Alignment plays into it as well, before I rebuilt my front end I had less clearance
Re: 67 GTX tire size question [Re: 1970RT] #2503592
06/02/18 02:22 PM
06/02/18 02:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You have a skinny wheel and tire combo, that will make huge difference. A 6 or 7 inch wheel with a wide tire like a 235 70 is a whole different thing. Not a fair comparison.
Look how high you car is sitting, you can see the top of the front tire, and see the tire over the top of the rim in the rear. Definitely raised up on all four corners. Some folks don't want their car sitting that high.
