Page 3 of 3 1 2 3
Re: Sneak peek pecker extension [Re: WHITEDART] #2502229
05/30/18 01:51 PM
05/30/18 01:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I may be out in left field here, but if I were to put one on my car I'd want it to trip everything but the pre stage/stage beams, even under full power.
Re: Sneak peek pecker extension [Re: justinp61] #2502233
05/30/18 02:00 PM
05/30/18 02:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what you want.. mount the stripe taker about
4" off the ground with you in it... some cars get
higher at speed some get lower
wave
Re: Sneak peek pecker extension [Re: Spaceman Spiff] #2502264
05/30/18 03:12 PM
05/30/18 03:12 PM
an8sec70cuda Offline
Originally Posted By Spaceman Spiff
Originally Posted By an8sec70cuda
Originally Posted By MoparBilly
The little secret they don't want to mention is that it also increases MPH readings 3-5 mph, so they can brag about how much more Horsepower they have.
How does it do that? If the cones/beams down track are all the same height (lower than the stage beam), how does the extension make the MPH faster? I understand the ET being slightly quicker b/c the distance travelled is thrown off w/ the extension.
MILES PER HOUR TIMER
Also known as the speed trap, this timer is located 66 feet before the finish line. It records the car’s average speed between it and the finish line. This is the mile per hour figure on your time slip.
So, if the car got there sooner, with the extension, would it fool the timer into a faster speed?
My understanding is that the MPH is measured on how long it takes the car to break the last two beams at the end of the track. The extension breaks these two beams, unlike the stage beams which are broken by the tires. With an extension, the car will technically get to the last two beams quicker, but it will not change the speed at which it breaks both of them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sneak peek pecker extension [Re: WHITEDART] #2502276
05/30/18 03:27 PM
05/30/18 03:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Starting line beams are usually right at 1.5"+-. The top end beams are generally 6"+-. The Rulebook has a 3" minimum rule to make sure you clear. Means nothing about how high the beams are. If the rules allow a pecker extender then why not take advantage of it. Some of the new late model cars have 40" of front overhang on them. Meaning when you leave the have an immediate 40" advantage on cars like a Dart that is not in the weeds.
I believe the NHRA's current stance on pecker extenders is they are not legal. They are only allowed to be even with the farthest point forward on the car, ie the leading edge of the front bumper. Many many bracket cars use stripe takers on the front end. Once of those things you need to pay attention to in the lanes for sure.
Re: Sneak peek pecker extension [Re: Al_Alguire] #2502593
05/31/18 10:08 AM
05/31/18 10:08 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
thank you for clarifying The Starting Line beam height.. I will be taking the car out tonight to test the new converter as well as the extension.. hopefully all goes well
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Sneak peek pecker extension [Re: an8sec70cuda] #2502699
05/31/18 02:04 PM
05/31/18 02:04 PM
Locomotion Offline
Locomotion  Offline
MPH will be faster if a driver can break the beams with the front tires but hit the brakes and dip the nose for a stripe taker or spoiler to trip the last MPH beam, which is also the finish line/stop ET. They wouldn't be losing much actual forward momentum, but it can dip the front with soft springs/shocks.
Re: Sneak peek pecker extension [Re: WHITEDART] #2502745
05/31/18 03:58 PM
05/31/18 03:58 PM
Myron, you're right, that's the only way the MPH could be affected. From what I've seen of the cars running these extensions, they are fast enough that the front of the car is slammed to the ground at speed for aerodynamics. Not to mention the speeds they're running. I find it hard to believe any of them are diving on the brakes to "gain" a couple mph.
CHIP
Re: Sneak peek pecker extension [Re: an8sec70cuda] #2502776
05/31/18 05:32 PM
05/31/18 05:32 PM
Locomotion Offline
Locomotion  Offline
Not for MPH, but it can still throw off the opponent when he doesn't know where to judge - if the lights are being tripped with the wheels or the strip taker/spoiler.
Re: Sneak peek pecker extension [Re: WHITEDART] #2502794
05/31/18 06:08 PM
05/31/18 06:08 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Let's say you have a car that goes 140 mph in the 1/4. If you add a pecker extender, how much ET do you lose per inch?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sneak peek pecker extension [Re: Hemi_Joel] #2502800
05/31/18 06:24 PM
05/31/18 06:24 PM
You should gain ET, run quicker, by some .0001s, not loose it due to the clocks stopping sooner off of the stripe taker, correct work
If your traveling at 140 MPH when you multiplied 140 MPH by 5280=739200 which is the feet per hour, correct work If you multiply that by 12 inches for inches per hour you get 8870400 inches per hour which = inches per minute when you divide that by 12=147840 inches per minute which divided by 60 again to get the feet per second=2464 inches per second which also = 205.33 Ft. per second, correct work grin
If you took a 18 inch extension for the stripe taker from the front edge of the tires it should be the same as dividing 2464 by 100 to get the inches per one hundred of a second, correct confused 2464 divided by 100 =24.64 inches per .01 ET so the gain should be less than .01, correct work scope
I'm not a math guru or drag racing geek so those more in the know on this please chip in if I have part of this math incorrect please so I can learn the proper way to figure things like this out bow devil up
Re: Sneak peek pecker extension [Re: WHITEDART] #2502841
05/31/18 07:16 PM
05/31/18 07:16 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
OK, Cab, I took your math to the next level and came up with this:
.000002857 per mph per inch. So lets look at an 18" extender at 140: 18x140x.000002857 = .0072 quicker ET.
At 200 mph: .010
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Sneak peek pecker extension [Re: Hemi_Joel] #2502860
05/31/18 07:48 PM
05/31/18 07:48 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I read an article on them and their math is very similar to Hemi Joel's. It ain't much but for a competitive racer... it all counts. I personally don't like them at all but I get it.
Re: Sneak peek pecker extension [Re: WHITEDART] #2502899
05/31/18 09:12 PM
05/31/18 09:12 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
This came into our shop for repairs today. He says it's a work truck, but I think it's one of those sleepers with an adjustable pecker. What do you guys think?
Re: Sneak peek pecker extension [Re: sgcuda] #2502908
05/31/18 09:23 PM
05/31/18 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Too far up in the air.. needs to be a lot lower
wave
Re: Sneak peek pecker extension [Re: MR_P_BODY] #2502910
05/31/18 09:26 PM
05/31/18 09:26 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
wave
It's hard. whistling biggrin
Page 3 of 3 1 2 3
