Re: 67 GTX front brake question
[Re: 69BBCUDA4SPD]
#2502494
05/31/18 12:20 AM
05/31/18 12:20 AM
RapidRobert
A pull to the right (& vice versa) means the left side ain't doing its job. spoon up the left side (wheel off the ground/spin it forward/spoon it till you barely hear a "tick" at one point in the tires' revolution, a tick that you "hear" but do not see/feel it slowing down the wheel revolution). & see what happens & if not satisfactory then open it up & see what you see.
