From hard to soft brake pedal after short drive? #2496788
05/16/18 10:55 AM
05/16/18 10:55 AM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
I have a problem that my break pedal goes soft after five minutes of driving. A quick dobbel pump of the pedal and it's hard and feels right again. Suspected trapped air in the brake system but after traditional bleeding, bleeding with vacuum and reverse bleeding (pushing fluid from calipers) I find it hard to believe that there is still air trapped in the system.
Current brake system is based on SSBC A-156 four piston calipers with a 11.25" rotor, OEM drum drum distribution block, SSBC A0707-1 prop valve to adjust pressure to the rear circuit, Doctor Diff 15/16" master cylinder (manual brakes) and Doctor Diff 10,7" rear disc brake kit based on Ford Mustang cobra OEM calipers.
I had the same problem last summer with the same brake set up except from 10" drums in the rear and SSBC 1.032" master cylinder up front.
Starting to lean towards that the problem could be related brake pad knock back so I checked for play at the wheel bearings but they nice and tight.
Anyone have any Idea that could cause this problem?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2496912
05/16/18 06:42 PM
05/16/18 06:42 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Clamp down either the front or rear hose(s) to pinpoint the problem.
Any residual pressure valves present in the system?
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2496940
05/16/18 08:06 PM
05/16/18 08:06 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Rotor run-out can also knock the pads back
Angry white pureblood male
Re: From hard to soft brake pedal after short drive? [Re: ruderunner] #2496982
05/16/18 10:36 PM
05/16/18 10:36 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
.. but wouldn't you feel the pulsation pretty clearly in your feet, via the pedal? ..and he checked the runout..
not that I have an answer.. unusual for a disc brake setup... if this is behaving different than last year when you had drums, I'd focus on the new disc setup you changed.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: From hard to soft brake pedal after short drive? [Re: 67SATisfaction] #2497361
05/17/18 09:21 PM
05/17/18 09:21 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
- Art
Pad knockback due to bearing compliance when cornering isn't all that uncommon for aftermarket setups, and will not provide you with a pulsation.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2497380
05/17/18 11:00 PM
05/17/18 11:00 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I had this sort of problem and it was the rear wheel cylinders, that I had replaced.
The part number was correct but it was really a wheel cylinder for the earlier Drums.
here is a clip from Mopar Actions Rick Ehrenberg's Disc o tech.
>> In the mid-1970s, Chrysler eliminated the rear brake residual pressure valve from the master cylinder. Its function was to prevent any air from sneaking into the system via the rear wheel cylinder cups. In its place, Chrysler substituted "expanders" in the rear wheel cylinders. (Expanders are dish-shaped steel inserts that exert outward pressure on the cups.) If you should decide to use a master cylinder from a 1975-up car, be sure you have the expanders in your rear wheel cylinders. For at least 20 years they have been universal in all replacement wheel cylinders and rebuild kits.
Opps, I jumped ahead of your question. I see now you have rear discs. I don't have an answer.
Re: From hard to soft brake pedal after short drive? [Re: boydsdodge] #2497820
05/19/18 11:22 AM
05/19/18 11:22 AM
moparx Offline
moparx  Offline
possibly install an aftermarket 2# check valve like speedway motors and other outfits sell ?
beer
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2498035
05/19/18 10:45 PM
05/19/18 10:45 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
67sat, he checked bearing play, not run-out. Also, run-out by itself doesn't cause pulsating, that's thickness variation which can be caused by run-out.
At least we can pretty much rule out the rear brakes as the cause. But...
Is the problem more noticeable with the difference in master cylinder bores? Thinking the larger bore would have covered it up to some extent.
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2500492
05/25/18 10:57 PM
05/25/18 10:57 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
any resolution on this?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: From hard to soft brake pedal after short drive? [Re: astjp2] #2500570
05/26/18 07:53 AM
05/26/18 07:53 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I would go through and tighten all the brake lines with line wrenches to make sure no air is coming in. Might be in an area where you won't see a little drip in a short drive. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2500576
05/26/18 08:48 AM
05/26/18 08:48 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Using a dial indicator check the end play on the rear wheel bearings.
Set it to 0.0050 inches
Using a beam style torque wrench set the front wheel bearing pre-load to 125 inch pounds whilst spinning the rotor-after seating the bearings of course. INCH pounds.
Re: From hard to soft brake pedal after short drive? [Re: ThermoQuad] #2502337
05/30/18 05:35 PM
05/30/18 05:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By Dilbert
Using a dial indicator check the end play on the rear wheel bearings. Set it to 0.0050 inches
That's a bit tighter than stock, stock spec is .008*.018"
That's half the procedure and the spec is off. Per the 72 Plymouth FSM, other years similar.
Adjustment:
(1) Tighten wheel bearing adjusting nut to 90
inch-pounds while rotating wheel.
(2) Position nut lock (Fig. 10) on nut with one
pair of slots in line with cotter pin hole.
(3) Back off adjusting nut lock assembly one slot
and install cotter pin. The resulting adjustment
should be zero (no preload) to .003 inch end
(4) Clean the grease cap, coat inside with wheel
( 5 ) Install wheel covers and lower vehicle to floor.
If you tighten to 125 in/lbs and leave it there, you'll be back doing new bearings.
Don't be the exception.
Re: From hard to soft brake pedal after short drive? [Re: Supercuda] #2502340
05/30/18 05:44 PM
05/30/18 05:44 PM
ThermoQuad Offline
ThermoQuad  Offline
Take the fsm and ignore it as 22+ years of laps says
125 INCH pounds
End play on rear bearings 0.0050
Last car I built had 4 wheels discs with no issues...
I forgot you guys are smarter than me
Re: From hard to soft brake pedal after short drive? [Re: ThermoQuad] #2502346
05/30/18 05:54 PM
05/30/18 05:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
125 INCH pounds
You leave that at 125 inch pounds and you'll be putting in bearings sooner rather than later
Re: From hard to soft brake pedal after short drive? [Re: Supercuda] #2502560
05/31/18 07:04 AM
05/31/18 07:04 AM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
After further investigation of my problem I'm 99% sure my problem is caused by deflection that knocks that pads off the rotors. I measured rotor run out with a dial indicator, changed wheel bearings (set them up properly) and I still have the problem. I can pump the pedal to get it hard on the garage floor and then grab hold of one of front wheels and then rock the wheel / the whole car and when I then push the brake pedal it's noticeable softer. Could the deflection resulting in pad knock back be caused by the smaller drum brake spindle diameter and the smaller bearings that the drum brake spindle got? What also got my attention is my 8" wide rims with little backspace putting more leverage and force to the spindle and bearings. Could new spindles with lagers dim bearings offer less defection and keeping the brake pads closer to the rotor even on rougher road surface and tight cornering where I normally feel problem being largest?
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2502561
05/31/18 07:16 AM
05/31/18 07:16 AM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
here is a picture of my set up.
Re: From hard to soft brake pedal after short drive? [Re: cudaerik] #2502823
05/31/18 06:55 PM
05/31/18 06:55 PM
The Netherlands
The Netherlands
Any pictures of the bleeder location?
I see the brake line entering the caliper 'fairly' high.
Re: From hard to soft brake pedal after short drive? [Re: BigBlockMopar] #2505083
06/06/18 06:05 AM
06/06/18 06:05 AM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
Here is a picture of the caliper that I'm using, bleed screw is located higher and on the other side of the caliper that where the hose is attached.
