polishing tail light lenses? #2499558
05/23/18 04:59 PM
05/23/18 04:59 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Does anybody have any tips on polishing tail light lenses on a 70 challenger. I seen graveyard carz use some water acid mix. Not sure if I want to chance that. Thanks guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: polishing tail light lenses? [Re: stickman] #2499595
05/23/18 06:02 PM
05/23/18 06:02 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
I used Plast-X by Meguires and a foam pad on a drill to polish my 70's lenses. Came out decent after about an hour's worth of work.
Re: polishing tail light lenses? [Re: stickman] #2499612
05/23/18 06:48 PM
05/23/18 06:48 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Wet sand them and slowly bring them up to 1000 grit or so.
320 grit would just be a guess. Depends how scratched they are.
Then hit them with the plastic polish.
Car polish will work too. So does toothpaste.
Re: polishing tail light lenses? [Re: stickman] #2499670
05/23/18 08:55 PM
05/23/18 08:55 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I put them in the glass bead cabinet and lightly etch the entire surface, especially the corners.
Then I clear coat them. Spray bomb clear won't work, it takes clear from the gun. It will only take a couple of ounces, so the extra from most any paint job will be more than enough.
The clear will make the surface look shiny and new and it is harder and more scratch resistant than the plastic itself.
We also sand and clear coat the dull headlights in newer cars. Makes most look new again. And they stay that way, unlike polishing.
Master, again and still
Re: polishing tail light lenses? [Re: stickman] #2499691
05/23/18 09:58 PM
05/23/18 09:58 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have used mothers mag wheel polish on all my lenses. Even the speedo lens. Works great.
Re: polishing tail light lenses? [Re: stickman] #2499831
05/24/18 02:57 AM
05/24/18 02:57 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: polishing tail light lenses? [Re: DaveRS23] #2499835
05/24/18 03:15 AM
05/24/18 03:15 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
What grit do you use on the headlights? Thanks
Re: polishing tail light lenses? [Re: mopars4ever] #2499851
05/24/18 07:26 AM
05/24/18 07:26 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've done this as well.
'63 Dodge 330
11.19 @ 121 mph
Re: polishing tail light lenses? [Re: stickman] #2499885
05/24/18 10:24 AM
05/24/18 10:24 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Saw this as a demo at a trade booth, Wenol Metal Polish (Red), works very well.
I suspect it may be similar to the mag polish some have recommended.
Re: polishing tail light lenses? [Re: NANKET] #2499891
05/24/18 10:41 AM
05/24/18 10:41 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Depends on just how bad the surface is. 600 to 1000 typically. It's not real critical. Sand scratches don't usually show through.
But you do need to remove some material. The light's surface will be rough and the damaged plastic needs sanded off.
And have a heat gun or hair dryer handy. The lights are quick to "blush". But a little heat clears them right up.
Re: polishing tail light lenses? [Re: DaveRS23] #2499920
05/24/18 11:54 AM
05/24/18 11:54 AM
California
biggE Offline
biggE  Offline
California
I use a metal polish called Wenol. It does a nice job on plastic head light lenses also.
Re: polishing tail light lenses? [Re: stickman] #2499967
05/24/18 01:38 PM
05/24/18 01:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use a cutting buffing compound, no need to sand first... the compound does that for you.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: polishing tail light lenses? [Re: mopars4ever] #2499995
05/24/18 02:50 PM
05/24/18 02:50 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
^^^^^^^^^^^^^^^^^^^^^^^^^ This
Re: polishing tail light lenses? [Re: stickman] #2500021
05/24/18 03:41 PM
05/24/18 03:41 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Used the Meguires plastic cleaner and then plastic polish on my 70 Sport Sat lenses . . .took my time, and when thru them a few times, then finally used a cleaner/wax on them . . .turned out perfect. Sure it took more time than the sand paper route, but I did not want to be too aggressive with 1970 lenses ! . . . on my "new" cars, I always give the lenses a going over with the "cleaner/wax" that I would use on the body of the car. Keeps the lenses looking new !!! . . .
Re: polishing tail light lenses? [Re: GY3] #2501262
05/28/18 10:59 AM
05/28/18 10:59 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
So have I; with great success. Anything with light grit that can cut will work. I often use paint polishing compound for things like this too.
Re: polishing tail light lenses? [Re: stickman] #2502043
05/30/18 12:35 AM
05/30/18 12:35 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Crest toothpaste with damp cotton cloth, follow by wash with detergent, to finish apply plastic polish (novus or mothers plastic polish)
Re: polishing tail light lenses? [Re: stickman] #2502067
05/30/18 01:22 AM
05/30/18 01:22 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Clear cote them!
Have a great day
Iowan
"obsolete is neat"
Re: polishing tail light lenses? [Re: Iowan] #2502086
05/30/18 02:24 AM
05/30/18 02:24 AM
Phila
P
PhillyRag Online content
PhillyRag  Online Content
P
Phila
Ever try removing CC from a lens? The 2 part clear are b**ch to remove if needed.
Re: polishing tail light lenses? [Re: stickman] #2502100
05/30/18 03:04 AM
05/30/18 03:04 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Why would you need to, but if that is a concern use clear lacquer. It is available in an aerosol.
Have a great day
Iowan
"obsolete is neat"
Re: polishing tail light lenses? [Re: shawge] #2502268
05/30/18 03:17 PM
05/30/18 03:17 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
This is what I've used on the instrument cluster lense. Took several treatments to achieve the effect I wanted, but I liked that it was mild.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
