Trim Rings for 15 X 8 Rallye Wheels
#2501738
05/29/18 01:56 PM
05/29/18 01:56 PM
Posts: 3,674 The Historic Hudson Valley
MONC
Are there trim rings available that fit a 15 X 8 Rallye wheel, or do I have to live with an inch of gap with a 15 X 7 ?
Mopar Or No Car
Re: Trim Rings for 15 X 8 Rallye Wheels
[Re: MONC]
#2501879
05/29/18 05:40 PM
05/29/18 05:40 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Yeah, looked at Jeg's and Coker as well this morning, really didn't see anything definitive.. Yeah, I've bought 15X8 trim rings from Jegs, Wheel Vintiques, even JC Whitney! and a few other sources that looked promising for a factory looking trim ring, some were real nice, they just didn't fit on the rim....here's the factory 15X7 ring on Wheel Vintiques 15X8
[Re: DAYCLONA]
#2502014
05/29/18 11:18 PM
05/29/18 11:18 PM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
Man, im not a fan of the gap. I always get rid of 14in rallye rims and the 8in wide 15s. Not sure id even like 8s if the trim ring fit. My friends say im a little different, lol.
Stand behind your word
[Re: topside]
#2502245
05/30/18 02:28 PM
05/30/18 02:28 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I use the 15x6.5 trim rings on my front 15x7 wheels and the 15x7 trim rings on my 15x8 rear wheels at least the gap is the same
NS1AAR
[Re: autoxcuda]
#2505949
06/08/18 02:57 PM
06/08/18 02:57 PM
Posts: 64 MA
Kevin Kowalski
MA
A little more drastic work-around...
You could run 5 1/4” backspacing and run a 1” spacer or a 2” overall wider rear end.
Wheel will look like a 15x7 from the side. That's what I did. I ordered 15x8 rallyes from Stockton Wheel in CA with 1" more backspacing than a stock 15x7. IIRC it was 5-1/4" like autoxcuda stated. I also moved my springs inboard about 3/4" per side for clearance. This gave the correct fit for the trim ring with no gap and the outside of the tire and wheel are in the stock location with a stock width rear housing.
[Re: DAYCLONA]
#2507596
06/12/18 05:51 PM
06/12/18 05:51 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Yeah, looked at Jeg's and Coker as well this morning, really didn't see anything definitive.. Yeah, I've bought 15X8 trim rings from Jegs, Wheel Vintiques, even JC Whitney! and a few other sources that looked promising for a factory looking trim ring, some were real nice, they just didn't fit on the rim....here's the factory 15X7 ring on Wheel Vintiques 15X8 I used the polished Wheel Vintiques 15x7 trim rings on a set of 8" wheels stretched by Stockton Wheel back in the day. They look identical. You don't get ugly until you go to a 10" stretch. Those look darn ugly.
I’m listening.
