Finally Dynoed my new bullet today
#250160
03/10/09 10:09 PM
03/10/09 10:09 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
After a long wait and some problems dynoed my new 367ci small block today I was impressed you think it will put me in the 10's 575 hp @ 6800 rpm 490ft torque @ 5300 rpm's Darn Cometic gaskets keep leaking around the head studs Car weights 3125 8" 5500 stall converter 4.56 gears 30 " tall slick Cal racs and Mono leafs
Switched to the dark side...
Re: Finally Dynoed my new bullet today
[Re: JSR1485]
#250164
03/10/09 11:27 PM
03/10/09 11:27 PM
fast68plymouth
So. Burlington, Vt.
weedlayers 419 made like 580hp. runs 10.40's-50's in a 3400lb Challenger.
[Re: JSR1485]
#250165
03/11/09 09:50 AM
03/11/09 09:50 AM
Posts: 189 long island new york
kingdust
I had a .040 340 with w2 econos made 540 at the flywheel, with a 4spd and 489 gears in a 3000lb duster,I went a best of 10.70 at 125 at atco! I launched at 6000,anything below that and the car would bog off the line because it didn't make a lot of torque. You'll definately be in mid 10s. Good luck.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: kingdust]
#250166
03/11/09 10:48 AM
03/11/09 10:48 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Jason I am glad to see you have the new bullet up and running.. Nice numbers by the way.. See ya at the track
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Dap]
#250168
03/11/09 04:39 PM
03/11/09 04:39 PM
JSR1485
Seaford Delaware
Thanks Rob hope to see you at Etown once again, No sure what the problems was with head gaskets yet. I am waiting to hear back from Dave @ RBRE They Dyno'd it again to and the HP went up to 585HP and the torque went up also. Not bad for a steel headed small block
[Re: 2QUICK4U]
#250170
03/11/09 04:55 PM
03/11/09 04:55 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
What do you have into that 367... heads, cam, comp ratio, what size carb, i have a 365 but i am not going to dyno it and was wondering how close my set up is to yours.
thanks
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#250171
03/11/09 08:20 PM
03/11/09 08:20 PM
JSR1485
Seaford Delaware
I have Scat crank, Scat H beam rods, Diamond special made pistons -12.8 to 1 ,Cam Motion roller cam 690/700 106.5 center 1.7 and 1.6 jessel rockers, Steel heads flowed by Brandywine heads for I.R.O.C flow 297cfm @ 700 lift ,Victor 340 intake 750 holley HP carb redone.
[Re: JSR1485]
#250172
03/11/09 10:43 PM
03/11/09 10:43 PM
65signet
El Dorado Ca
You have alot more compression and cam than i do.. is that just a 360 bored out or a storker
[Re: JSR1485]
#250174
03/14/09 12:16 AM
03/14/09 12:16 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Happy b-day! And nice dyno numbers!
