AAR T/A Splash Shield #2501439
05/28/18 08:25 PM
05/28/18 08:25 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I believe I know the answer but want to be sure as I can see that several I consider to be highly knowledgable have provided different views on the topic over the years.
1st - We're talking about the splash shield, often called a starter shield but believed to be a transmission cooler line shield, located on the LH side of an E-body.
If I understand things correctly, as this pertains to AAR's and T/A's
1) these were on Auto cars only (no 4-speeds)
2) auto cars with STD steering received plastic shields
3) auto cars with fast ratio steering received metal shields
Looking for confirmation as the clips I've posted have some conflicting information. I'm not trying to call anyone out, no disrespect to MOPARTS or E-Bodies since snips are from both, I posted on MOPART's because more snips came from that site.
Thanks for the guidance.
Screen Shot 2018-05-28 at 2.30.45 PM.pngScreen Shot 2018-05-28 at 2.32.39 PM.pngScreen Shot 2018-05-28 at 3.03.24 PM.png
Re: AAR T/A Splash Shield [Re: AAR#2] #2501440
05/28/18 08:26 PM
05/28/18 08:26 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
the final 2
Screen Shot 2018-05-28 at 2.55.17 PM.pngScreen Shot 2018-05-28 at 2.58.32 PM.png
Re: AAR T/A Splash Shield [Re: AAR#2] #2501458
05/28/18 09:05 PM
05/28/18 09:05 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 AAR with fast ratio steering & automatic transmission;
Re: AAR T/A Splash Shield [Re: Alaskan_TA] #2501626
05/29/18 10:32 AM
05/29/18 10:32 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thanks Barry, assuming this is a survivor, it supports what I believe to be true for item 3) auto cars with fast ratio steering received metal shields.
I also believe item 1) these were on Auto cars only (no 4-speeds), is pretty well uncontested.
What remains open for comment/debate is item 2) auto cars with STD steering received plastic shields.
Re: AAR T/A Splash Shield [Re: AAR#2] #2501720
05/29/18 01:24 PM
05/29/18 01:24 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
So no shield for 340+6 4-spd cars with fast ratio steering?
Nicklas
Re: AAR T/A Splash Shield [Re: 71redcuda] #2501777
05/29/18 03:23 PM
05/29/18 03:23 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Nicklas
Better yet, 340+6 4-speed cars don’t get this shield at all, doesn’t matter what steering system is installed.
Re: AAR T/A Splash Shield [Re: AAR#2] #2505861
06/08/18 10:43 AM
06/08/18 10:43 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: AAR T/A Splash Shield [Re: AAR#2] #2506006
06/08/18 06:35 PM
06/08/18 06:35 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Hey Barry
Mind if I borrow that picture?
