Throttle bracket for Quick Fuel carb #2501145
05/27/18 10:46 PM
05/27/18 10:46 PM
State, country, etc.
gss Offline OP
gss  Offline OP
My Jegs throttle cable bracket worked great with my Holley carb but the float bowls on my new QF 1050 are wider and the bracket doesn't fit.
I can find throttle brackets that are made for the Quick Fuel carb but they don't accept the Chrysler-style throttle cable.
Does anyone have a great throttle bracket with return springs that fits a QF carb?
Re: Throttle bracket for Quick Fuel carb [Re: gss] #2501154
05/27/18 10:58 PM
05/27/18 10:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Son needed one so I made it out of square stock. Easy project
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Throttle bracket for Quick Fuel carb [Re: pittsburghracer] #2501156
05/27/18 11:00 PM
05/27/18 11:00 PM
PA.
"Little"John
"Little"John
PA.
I should add I used their bracket and only had to make the part that holds the stock mopar cable.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Throttle bracket for Quick Fuel carb [Re: gss] #2501160
05/27/18 11:04 PM
05/27/18 11:04 PM
AndyF Offline
AndyF  Offline
Mancini Racing and Hughes Engines sell throttle brackets.
Re: Throttle bracket for Quick Fuel carb [Re: AndyF] #2501227
05/28/18 04:44 AM
05/28/18 04:44 AM
gss Offline OP
gss  Offline OP
This is the style I am looking for. The loop around the front accel pump to the front left carb stud just needs to be a little less curved so it doesn't hit the float bowl. Quick Fuel makes the bracket which I assume fits their carbs, they just don't fit the Mopar cable.
Re: Throttle bracket for Quick Fuel carb [Re: gss] #2501374
05/28/18 05:21 PM
05/28/18 05:21 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use Andy's bracket on my car with a few different carb and intake combinations and it works well for all of them shruggy
Gus beer
64 Plymouth Savoy
Dana 60
