Special /Specific Mopar hardware where to get #2500863
05/27/18 12:15 AM
05/27/18 12:15 AM
west palm beach, florida
modelmakerinc Offline OP
Wondering if there is a place to get the unique, specific, special type bolts for our cars. There are so many different applications and locations but the ones I am looking for are the 4 steering knuckle to spindle bolts and castle nuts.
The bolts are lower profile head and has the hole for cotter pin.
There are lots of other special hardware, where do you guys find them or are most from taking parts cars apart.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2500866
05/27/18 12:33 AM
05/27/18 12:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Name the specific application and chances are that someone has some good used OEM hardware. The factory stuff is the best to use. It fits, it is durable and is correct in appearance.
I have yet to buy any hardware from a repro-vendor except for a Grille kit for my 70 Charger. There are specific plastic spacer/washers that would be just as bad from a parts car as my own were.
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2500871
05/27/18 12:57 AM
05/27/18 12:57 AM
Yeah, I was thinking that the original unique application type hardware would only be used oem, I would strip every piece of hardware from the parts cars that Ive had and I have a good amount of hardware but slowly been using it.
The car is a 67 Coronet, I sold the stock factory disk brakes and am replacing it with drum spindles and wilwood brakes and all new wear parts, I didn't think to keep the hardware it went with the sale.
I would be happy to buy them from a member
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2500892
05/27/18 02:46 AM
05/27/18 02:46 AM
AndyF Offline
AndyF  Offline
AMK makes a lot of original hardware. If they don't have it then it probably doesn't exist. Some used stuff isn't too hard to find since Mopar used the same bolts for a lot of years, but the older stuff is drying up.
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2501235
05/28/18 07:09 AM
05/28/18 07:09 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
http://www.amkproducts.com/
Spend some time figuring out their web site, and you'll find lots of good stuff.
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2501340
05/28/18 03:28 PM
05/28/18 03:28 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
They have their catalog on PDF which is nice. They sure do have a lot of stuff, gonna bookmark it. Thanks!
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2501355
05/28/18 04:05 PM
05/28/18 04:05 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
If you contact MrMoparts they'll put a kit together for you.
Abe Lincoln
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2501360
05/28/18 04:21 PM
05/28/18 04:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does a regular profile bolt head interfere with anything? If you are running Wilwood brakes I'm thinking OEM correct appearance isn't a high priority. If there is an interference issue, you could trim the heads down on a lathe.
Kevin
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2501561
05/29/18 01:20 AM
05/29/18 01:20 AM
Thanks for the links and suggestions guys.
I have a couple local guys looking for some for me hopefully either someone here or home will come up with a set.
Two stick, I could turn down the heads and drill holes for the cotter pins (X4) but I just rather not go through so much trouble for hardware that should be available
Re: Special /Specific Mopar hardware where to get [Re: modelmakerinc] #2501900
05/29/18 06:29 PM
05/29/18 06:29 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
RT Specialties is another place that has a lot of unique stuff.
http://www.rtspecialties.net/
1972 Dodge Challenger
