Re: Need help with overheating issues on 2006 PT Cruiser.
[Re: Dixie]
#2500747
05/26/18 07:10 PM
05/26/18 07:10 PM
Posts: 4,848 Memphis
HemiRick
Memphis
If it's losing coolant but not on the ground the only other choice is a head gasket leak and its going out the exhaust....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2500757
05/26/18 07:40 PM
05/26/18 07:40 PM
Posts: 21,447 It's a dry heat
gtx6970
It's a dry heat
If it's losing coolant but not on the ground the only other choice is a head gasket leak and its going out the exhaust.... Yep, Did one for this exact issue last year. ROYAL PIA job by the way Look REALY close on the pass side of the engine towards the front of the car, just below the area where the thermostat hsg is located.
[Re: Dixie]
#2500971
05/27/18 12:15 PM
05/27/18 12:15 PM
Posts: 12,161 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
First, check for combustion gases in the coolant which will tell you if you have a head gasket problem. There are a number of ways to do that. Do an internet search for your options.
Second, the fan has two speeds and it is very common for the low speed to go out. I have changed a bunch of them. In fact, it is common enough, that it would be a good idea to go ahead and change it.
And it is the fan motor itself that fails and only on the low speed. Not the relays. So, the fan assembly must be replaced.
It is possible now that the PT will have both problems. The fan problem leads to overhead problems, which kills the head gasket. As with many iron block, aluminum head engines, the PT's 2.4 is not tolerant of overheating.
Master, again and still
[Re: Dixie]
#2500993
05/27/18 01:44 PM
05/27/18 01:44 PM
Posts: 4,454 Morristown Tn.
71birdJ68
Morristown Tn.
IF, it going out the tail pipe, you need to fix it now. I had the same thing on my Neon, kept losing water, and I could even hear it gurgling back into the overflow bottle, and could smell anti freeze coming out the exhaust pipe. What was going on was the gasket working towards braking, then all of a sudden, all of the water will go out the tail pipe, and leave her sitting when the gasket lets go.
