42 re front pump seal issue #2500493
05/25/18 11:01 PM
05/25/18 11:01 PM
Central Illinois
Don_440 Offline OP
Don_440  Offline OP
Central Illinois
Working on 97 dakota with 42 re transmission,changing front pump seal,when removed,noticed what looks like a metal bushing or some kind of sleeve around outside seal or inside front pump bore repair?anybody seen this before. confused
Re: 42 re front pump seal issue [Re: Don_440] #2500704
05/26/18 03:48 PM
05/26/18 03:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is a bushing pressed into the pump housing behind the seal, sounds like it came out. Item #034 in the diagram below:
Re: 42 re front pump seal issue [Re: John_Kunkel] #2500766
05/26/18 08:08 PM
05/26/18 08:08 PM
Central Illinois
Don_440 Offline OP
Don_440  Offline OP
Central Illinois
Went to dealership,and had never seen it before,show me the same print.thought that was the inner pump support bushing,a service tech thought front pump was remanufactured or factory fix,bushing measures 2,25 i,d.,2.38 0.d. x .335 wide.,this bushingis going around seal.
Re: 42 re front pump seal issue [Re: Don_440] #2503438
06/02/18 01:44 AM
06/02/18 01:44 AM
A727Tflite Offline
A727Tflite  Offline
The trans plant mismachined some pumps back in the mid 90's and made the bore too large. Instead of scrapping them they made the sleeve you are talking about. If you are careful you can remove it and reuse it.
