Recipe for 1,000 HP gen III ( Hot Rod Article) #2497944
05/19/18 06:38 PM
05/19/18 06:38 PM
USA
hudsonhornet7x Offline OP
USA
Saw this today and found it interesting. Here you go:
http://www.hotrod.com/articles/build-pra...p;sf189858308=1
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: hudsonhornet7x] #2498148
05/20/18 10:57 AM
05/20/18 10:57 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
OOFTA!!! Peaks at 5200 rpm, imagine what it’d do with a real cam.....
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: hudsonhornet7x] #2498198
05/20/18 01:18 PM
05/20/18 01:18 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Brutal , and the best part is it doesn't have to spin 7k+ to make power,
doesn't show it on the chart but it starts to make 0ver 500FT @ 2900 Rpms and doesn't drop below a1k till 5300 rpms. that 71 Demon is going to be a rocket ship.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: ric3xrt] #2498242
05/20/18 02:27 PM
05/20/18 02:27 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Just off their price list that's approximately 18K for a 1000hp engine, for comparison sake...572 Indy Street wedge 17,495, 750hp, (base), Indy Gen 2 572, 770hp, 18,495 (base), Indy Gen 3 433" 6.1, 630hp, 20,860 (base). May not be an apples to apples comparison and it was just a quick reference but it sure seems to make this look like a pretty good deal up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: ric3xrt] #2498301
05/20/18 05:21 PM
05/20/18 05:21 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Is the water pump spinning backwards?
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: hudsonhornet7x] #2498814
05/21/18 10:40 PM
05/21/18 10:40 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I think the article is poorly written although I’m not surprise... not exactly a logical way to build an engine like this.
Step one. Buy overpriced crate
Step two Replace entire engine with aftermarket parts
Step three. Angerly pay credit car bills for overpriced engine you built.
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: hudsonhornet7x] #2499064
05/22/18 02:28 PM
05/22/18 02:28 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
I would run the crate as is. Can a JY block be machined and built including Apaches for that amount of money? And have a warranty?
I am researching and saving to ditch the Magnum in my Dakota. However I'd really like to run an 8 speed auto.
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: hudsonhornet7x] #2500375
05/25/18 05:03 PM
05/25/18 05:03 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
"The aluminum intake is the new Victor II from Edelbrock. It is designed to replace the stock 5.7L and 6.1L/6.4L plastic intakes."
Um, the 6.1l never had a plastic intake manifold.
No longer taking $h!t from anyone!
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: joshking440] #2500910
05/27/18 07:27 AM
05/27/18 07:27 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I agree with 1&2 , but I don't think there would be anger in 3,...reason being in order to do step 2 you have to PHUCKING HIGH, so when the CC bill comes in you would be still HIGH.
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: RapidusMaximus] #2501779
05/29/18 03:24 PM
05/29/18 03:24 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
$18K does not include the turbo system. You'd have to add for that.
Re: Recipe for 1,000 HP gen III ( Hot Rod Article) [Re: blowndart] #2501960
05/29/18 09:19 PM
05/29/18 09:19 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
New block 1500.00
used 6.4 crank 500.00 Can
used rods 500.00 can
new pistons 1000.00 US?
Cam near 800.00 US?
Lifters 350.00 US
oil pump 96.00 US
timing set 150.00 US
Heads used 5.7 will do just fine 1000.00 assembled
used 6.1 intake 300.00?
87 lb/hr Injectors FAST 30859-8 374.99
90mm Throttle Body Holley 112-589 466.95
Cable Bracket 90mm Holley 20-147 32.41
Dominator EFI Holley 554-114 1,990.95
FEAD Mopar 77072445 536.99
Hemi Main Harness Holley 558-116 467.95
Hemi Coil Harness Holley 558-311 107.95
Hemi Injector Harness Holley 558-210 107.95
Hemi Coil Drivers Holley 554-122 185.95
Injector Rails Edelbrock 3647 169.95
Oil Pan Milodon CALL CALL
Super Damper ATI 918486 384
11,017 total
Now you'll need two turbos, manifolds, gaskets and exhaust plumbing and someone to assemble it.
I'm I missing anything?
