70 AAR fuel line at carb...best kit?
#2499900
05/24/18 10:56 AM
05/24/18 10:56 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
The owner at my work has a 70' AAR and we need fuel lines for it at the carbs. Ordered a kit from Jim's I believe and it's a leaker. Anyone know of a good kit for these? thx
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 70 AAR fuel line at carb...best kit?
[Re: Eric]
#2499902
05/24/18 11:01 AM
05/24/18 11:01 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
First of all why would anyone buy anything from Jims? There are a number of good Mopar parts vendors out there, my favorite is Megaparts. Where is the line leaking? If it's at the threads, try putting some grease on the threads before tightening up. That will often do the trick as far as fixing fuel line leakage.
[Re: 70sixpkrt]
#2499983
05/24/18 02:20 PM
05/24/18 02:20 PM
Posts: 18,157 Mass
DAYCLONA
Mass
A lot of times they leak where the flare sits inside the fitting. Try using grease or teflon tape. I have heard that a lot of the new fuel lines leak now a days. NO tape, grease or teflon paste is recommended, plus a nice set of LINE WRENCHES, when you use a "regular" wrench on these fittings they distort the tube nut, basically egging it, so it dosen't seal/contact the flare 360 degrees, so it leaks....once egged, the fitting cannot be repaired and it will always leak no matter how tight you tighten it As far as sixpack fuel lines, I use FINELINES or RIGHT STUFF STAINLESS lines...zero issues if installed properly, I've done quite a few sixpack set ups using their lines Mike
[Re: DAYCLONA]
#2500014
05/24/18 03:30 PM
05/24/18 03:30 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
A lot of times they leak where the flare sits inside the fitting. Try using grease or teflon tape. I have heard that a lot of the new fuel lines leak now a days. NO tape, grease or teflon paste is recommended, plus a nice set of LINE WRENCHES, when you use a "regular" wrench on these fittings they distort the tube nut, basically egging it, so it dosen't seal/contact the flare 360 degrees, so it leaks....once egged, the fitting cannot be repaired and it will always leak no matter how tight you tighten it As far as sixpack fuel lines, I use FINELINES or RIGHT STUFF STAINLESS lines...zero issues if installed properly, I've done quite a few sixpack set ups using their lines Mike I meant teflon paste. Good catch.
[Re: Mastershake340]
#2500081
05/24/18 06:14 PM
05/24/18 06:14 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Grease on the threads is an old mechanics trick that oftentimes does the job. The grease itself isn't to improve the sealing. The threads might have a burr or slight imperfection and when you tighten the lines, they may not tighten all the way due to the imperfection. The grease will lube the threads and allow the fitting to be tightened completely thus resulting in a tight seal with no leakage. Doesn't always do the trick, but often it does, and it certainly is worth trying before going out and spending money on another set of lines! Agreed,...it's also a must do on Stainless lines/fittings as stainless galls easily, plus greasing/lubing the threads also makes disassembly easier years down the road regardless of the alloys employed...
[Re: DAYCLONA]
#2500158
05/25/18 12:17 AM
05/25/18 12:17 AM
Posts: 3,000 Long Island, NY
shakerjoe
Long Island, NY
I went with Fine Lines in non stainless for my 6 pack and all my fuel and brake lines, no leaks....took a few tries at my OE distribution block(pdb) to get it sealed using DOT5 fluid, but got it, as stated correct wrenches are a must, no galling, no slips and no scratches...no grease or teflon used either btw, just be careful and take your time and don't gorilla the fittings
[Re: shakerjoe]
#2500311
05/25/18 02:22 PM
05/25/18 02:22 PM
Eric
Pittsburgh PA
I went with Fine Lines in non stainless for my 6 pack and all my fuel and brake lines, no leaks....took a few tries at my OE distribution block(pdb) to get it sealed using DOT5 fluid, but got it, as stated correct wrenches are a must, no galling, no slips and no scratches...no grease or teflon used either btw, just be careful and take your time and don't gorilla the fittings Ordered from Fine Lines...thx guys..it's for my boss at work.
