Thoughts on cyl head repair #2498930
05/22/18 07:43 AM
05/22/18 07:43 AM
Sydney,Australia
tex013 Online content OP
tex013  Online Content OP
Sydney,Australia
Just interested in thoughts ideas about a cylinder head repair .
This is on my CNC source heads . Been fine for about 6 years , ran awesome on saturday
At work monday noticed a bit more moisture in valve covers , not unusual in winter with no pvc valve , normally gone after a weekend racing . Radiator down about a quart
Cleaned 1 cover , rechecked today . Worse .
Pulled heads to checkover .
2 cracks/splits in 2 different intake ports in 1 head . These are right through to headbolt passage , aluminium looks very thin , about 1/2" long.
Appears these may also intersect water ?
Is this simply drill and drive in a sleeve/tube situation ?
Or are these possibly done and beyond repair . The crack is quite down the port
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Thoughts on cyl head repair [Re: tex013] #2498938
05/22/18 08:52 AM
05/22/18 08:52 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
nice thing about alum is it can be welded up; if the welder can get to it. truth is there's probably other trouble spots that may show up. if it's possible i'd think about moving on to something else.
Re: Thoughts on cyl head repair [Re: lewtot184] #2498940
05/22/18 08:58 AM
05/22/18 08:58 AM
Sydney,Australia
Sydney,Australia
That is a big concern for sure
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2498947
05/22/18 09:29 AM
05/22/18 09:29 AM
crabman173
crabman173
Source heads are made from a very brittle and IMO low quality alloy--would be a waste of time to try and weld I think--get some Sidewinders or Trick Flows and keep on keeping on You may also find upon inspection that the guides are worn out--that metal looks like bronze but does not hold up well either
There have been folks that cracked those heads when tightening them down on the block
Re: Thoughts on cyl head repair [Re: tex013] #2499011
05/22/18 12:33 PM
05/22/18 12:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Have them pressure tested to see for sure where the water is coming from.
The head bolt holes "shouldn't" intersect water, but if they do...... Sealing that up is likely going to be a challenge.
Re: Thoughts on cyl head repair [Re: tex013] #2499040
05/22/18 01:34 PM
05/22/18 01:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would buy some Trick Flows and sell those to someone that wants to go thru the hassle of fixing them.
2011 Drag Pak Challenger
Re: Thoughts on cyl head repair [Re: tex013] #2499071
05/22/18 02:44 PM
05/22/18 02:44 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
O'Rielly's , probably others sell some block crack fix stuff , it a bright green bottle, guaranteed to stop leaks. Might try that first. A friend of mine used it on a BB Chevy intake gasket water leak . Surprised me that it worked.
Re: Thoughts on cyl head repair [Re: tex013] #2499105
05/22/18 03:50 PM
05/22/18 03:50 PM
Washington
madscientist Offline
Washington
Mr. Porter nailed it. You need to pressure test the heads and really see where the leak is. You can tube the bolt holes. But that won't stop your leak. Unless you have some weird deal where a crack in a water jacket is leading to that crack in the bolt hole.
Usually, that stuff only happens to me, but it is possible you got a bit of the green weenie.
Re: Thoughts on cyl head repair [Re: tex013] #2499185
05/22/18 07:47 PM
05/22/18 07:47 PM
Sydney,Australia
Sydney,Australia
thanks guys .
I will try and get them pressure tested next week .
Looks like TF270 are on the horizon . At least with the TF I can reuse my rocker gear so its just heads , bolts , pushrods
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2499239
05/22/18 10:39 PM
05/22/18 10:39 PM
Sydney,Australia
Sydney,Australia
Ok ,
just to go down the road a bit .
Which head gasket is good for the Tflow head ? Felpro 1009 , 8519 or buy the Tf cometic which doesn't have a 4.410 bore ?
I understand the Felpro max wedge intake is fine , or go Superformance .
I also need to buy TF rocker shaft studs , but my Crane Gold 1.5 rockers will be reused .
I currently use a 0.039 x 4.410 Cometic but may economise with the felpro if it works .
I know economy and racing are mutually exclusive but by the time parts arrive I am at double the US$ cost .
thanks again ,
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2499265
05/22/18 11:37 PM
05/22/18 11:37 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
How many "budget" racers have re used Cometic head gaskets ? I have, with only a week between races we had to try it, cleaned, copper spayed and perfect.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Thoughts on cyl head repair [Re: tex013] #2499714
05/23/18 10:49 PM
05/23/18 10:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By tex013
Ok ,
thanks again ,
Tex
I am running he Fel-Pro 1009 with the TF 240's and 12.3-1 compression and so far so good.
Re: Thoughts on cyl head repair [Re: tex013] #2499758
05/23/18 11:54 PM
05/23/18 11:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Leak check it to verify the crack but I would
sleeve it.. I had to sleeve 3 ports on my
W-2s and 1 port on my W-5.. so far its great..
use a mill to bore your holes
wave
Re: Thoughts on cyl head repair [Re: dartman366] #2499845
05/24/18 04:50 AM
05/24/18 04:50 AM
Sydney,Australia
Sydney,Australia
[/quote]I am running he Fel-Pro 1009 with the TF 240's and 12.3-1 compression and so far so good. [/quote]
KOOL
I have ordered the 270's , the 1009 will certainly save some $
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: MR_P_BODY] #2499846
05/24/18 04:55 AM
05/24/18 04:55 AM
Sydney,Australia
Sydney,Australia
wave
Mr Peabody ,won't chance it . Port wall is almost tissue thin . It would be hard to get at crack ends to drill to stop extending . And there is also thought of any other port cracking .
thanks
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2499849
05/24/18 05:33 AM
05/24/18 05:33 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Coat the sleeve with JB weld and send it!
Re: Thoughts on cyl head repair [Re: tex013] #2499861
05/24/18 08:49 AM
05/24/18 08:49 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
KOOL
Tex[/quote]
If your block has chamfered bores, those 1009 gaskets will likely overhang the bore.
Kevin
Re: Thoughts on cyl head repair [Re: Twostick] #2499865
05/24/18 09:07 AM
05/24/18 09:07 AM
Sydney,Australia
Sydney,Australia
KOOL
Tex[/quote]
Kevin [/quote]
It is 0.030 overbore . Yes i will check
Tex
New best MPH 130.32
Re: Thoughts on cyl head repair [Re: tex013] #2499903
05/24/18 11:04 AM
05/24/18 11:04 AM
So. Burlington, Vt.
So. Burlington, Vt.
Head gaskets...... Not really a good place to scrimp IMO.
I'd stick with the 4.410 Cometics.
What you're experiencing is why I prefer not to try and make a head into something it's not by excessively porting it.
If you need a bigger head....... And something is available.......its often less expensive in the long run to just get them at the start.
Re: Thoughts on cyl head repair [Re: tex013] #2499921
05/24/18 11:55 AM
05/24/18 11:55 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Sounds like you should be looking to upgrade on the heads sorry to say
