E-body radio delete ? #249956
03/10/09 07:18 PM
03/10/09 07:18 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
On E-body radio delete cars was the antenna fender hole punched and a plate to cover the hole used or was the fender hole not punched?
Re: E-body radio delete ? [Re: sbcjd] #249957
03/10/09 07:25 PM
03/10/09 07:25 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
My 1971 Cuda was ordered without a radio and the fender does not have a hole punched in it for the Ant.
1971 HEMI E BODY REGISTRY
Re: E-body radio delete ? [Re: sbcjd] #249958
03/10/09 07:38 PM
03/10/09 07:38 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
No hole in the fender.
My current customer bought his broadcast sheet off of EBay last month only to find out his 1971 Cuda was ordered without a radio. Much to my surprized he took his fender off and back to the body shop to fill the hole and repaint the fender. I guess it doesn't hurt that he owns the body shop
This makes three 1971 Cudas I've done that were "radio delete"
CHECK OUT MY NEW WEB SITE !
Re: E-body radio delete ? [Re: sbcjd] #249959
03/10/09 09:17 PM
03/10/09 09:17 PM
Smack dab in the middle of Ill...
JamaicaBlue Offline
JamaicaBlue  Offline
My 440-6 70 Challenger is "radio delete" with no hole in the fender. Someone did put a T/A hood on it and drill a hole in the rear quarter for an antenna.
Re: E-body radio delete ? [Re: sbcjd] #249960
03/10/09 09:33 PM
03/10/09 09:33 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
If something like a radio is not a standard item but an option you pay for how do you delete it???
Inquiring minds want to know....
Re: E-body radio delete ? [Re: ThermoQuad] #249961
03/10/09 09:40 PM
03/10/09 09:40 PM
anlauto Offline
anlauto  Offline
You're correct...the proper term is "ordered without" not delete.
Re: E-body radio delete ? [Re: ThermoQuad] #249962
03/10/09 09:41 PM
03/10/09 09:41 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
This is up there with all the 69-70 440 HP2's are sixpacks blocks.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: E-body radio delete ? [Re: AZ_A12_BEE] #249963
03/10/09 10:22 PM
03/10/09 10:22 PM
SE Pa.
LimeliteAero Offline
SE Pa.
Plymouth made those engines too ya know!
