#2499384 - 05/23/18 08:31 AM Nippondenso Alternator Questiion
80fbody Offline
Loc: Mass.
Are the Nippondenso alternators out of a 90's dodge internally regulated or do we still use the regulator on the firewall like the original alternators? Not sure how to wire the one I purchased awhile back.
1980 RoadRunner 360,4 speed,4:10 ---------------- 1968 Dart 451/727/4:30
#2499414 - 05/23/18 09:43 AM Re: Nippondenso Alternator Questiion [Re: 80fbody]
scratchnfotraction Offline
Loc: Florida
mine is a denso 120 amp external regulated on the 440 truck (not sure what it is from/double groove pulley)
I have a denso mini (smaller than my denso120amp) from 88 van/double pulleys that is external regulated. not sure what amp?
IIRC they ditched the VR on firewall in 89-93
if it has a serp pully I think those are internal regulated
swing by an autozone and have them toss it on the machine and test it. that will let you know for sure.
#2499419 - 05/23/18 09:59 AM Re: Nippondenso Alternator Questiion [Re: 80fbody]
savoy64 Offline
Loc: colorado
nope---serpentine means the computer runs it...
#2499424 - 05/23/18 10:08 AM Re: Nippondenso Alternator Questiion [Re: 80fbody]
80fbody Offline
Loc: Mass.
Mine came with serpentine and v groove pulley in the box. I'll have to get some numbers off it and see if I bought a dud....
#2499716 - 05/23/18 08:53 PM Re: Nippondenso Alternator Questiion [Re: 80fbody]
volaredon Offline
Loc: ILLINOIS
the alt doesn't know or care if it is being controlled by an external VR or a computer. That same alternator was used for about 8 years, and it was regulated both ways. and serpentine pulleys can be swapped out for V pulleys and vise versa easily enough... done so more than once.
on the 91s (seems worst year for VR part of computer brain frying) vans/pickups/Dakotas, I have seen them all with the regulator wires dug out of the harness and a plain old Mopar VR wired in.
#2499746 - 05/23/18 09:37 PM Re: Nippondenso Alternator Questiion [Re: 80fbody]
Andrewh Offline
you can wire it up with either the dual field vr from 74 and up or ground one of the field wires and use the single field wire vr.
I have mine wired up to a single field vr and just ran a ground wire to the plug.
the plug was the hardest thing to get. had to go to a yard to find one that wasn't clipped off.
25,631 Registered Members
195,641 Topics
WW-II History buffs should read....
by 360view
Today at 07:26 AM
1969 Plymouth Road Runner
by tomsjack
Today at 02:47 AM
How I keep track of my "Barn Finds"
by Devil
Yesterday at 11:43 PM
361 bb stroker
by orange elephants
Yesterday at 10:57 PM
