1963 Dodge hubcaps #2499204
05/22/18 08:40 PM
05/22/18 08:40 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Anyone know what the correct small hubcaps look like for a 1963 Dodge 2 door sedan - aka Max Wedge cars as an example
Re: 1963 Dodge hubcaps [Re: gtx6970] #2499836
05/24/18 03:15 AM
05/24/18 03:15 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I believe Dodge and Plymouth used the same cap for 63-64. Are you running stock 14" wheels, early pre-68 15" wheels or post-68 small center wheels?
Re: 1963 Dodge hubcaps [Re: 64Post] #2499853
05/24/18 07:31 AM
05/24/18 07:31 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use A-100 15" wheels on the front and used later style 15" Wheel Vintiques on the rear with the smaller center. I epoxied later model caps inside of two of the larger caps to make them work.
'63 Dodge 330
11.19 @ 121 mph
Re: 1963 Dodge hubcaps [Re: 64Post] #2499873
05/24/18 09:54 AM
05/24/18 09:54 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
thank you
Re: 1963 Dodge hubcaps [Re: gtx6970] #2500216
05/25/18 09:37 AM
05/25/18 09:37 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Just in case you have not seen this , it may help you out with some steel wheels.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2412794
Frank
Re: 1963 Dodge hubcaps [Re: gtx6970] #2500258
05/25/18 11:45 AM
05/25/18 11:45 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Frank
I appreciate the thoughts.
But my post was for model car related. ( another hobby of mine )
