Hood latch pops loose on its own
#2498647
05/21/18 02:46 PM
05/21/18 02:46 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I'm not sure if I've lost some rubber/plastic bushing or if something else is going on. If the latch is moved slightly forward, it will pop loose on its own, without releasing the locking tab. Action here: https://youtu.be/MKP1dKFxbPAIs this a known issue that can be fixed? The actual latch mechanism looks like it's riveted together. I'm not sure how to stop worrying about my hood popping up on the freeway short of getting hood pins.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Hood latch pops loose on its own
[Re: Secret Chimp]
#2498768
05/21/18 08:29 PM
05/21/18 08:29 PM
Secret Chimp
Eugene, Oregon
Well, I know I have a problem because it keeps popping open on the highway every now and then despite being tuggy-tight sitting still. 55mph+ air blowing at the hood + bumps seems to let it wiggle free easily. I probably just need a new latch.
[Re: Secret Chimp]
#2498812
05/21/18 10:37 PM
05/21/18 10:37 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
my guess is the spring that holds the pawl in the latch that secures the latch lever is broken or the pawl is rusted up or worn out.
your options try lubing with penetratant and hope it free up. disassemble and repair latch most likely you probably need a new latch
perception is 90% of reality
[Re: rapom]
#2499196
05/22/18 08:14 PM
05/22/18 08:14 PM
Secret Chimp
Eugene, Oregon
I used to have the exact same problem with my 67 Coronet. Before I did anything I adjusted the hood latch assembly so that I had to shut my hood a little harder (a soft slam) to close it and that did the trick. It's been about 4 years since I've had it happen.
I used to be able to shut my hood without slamming it. I would just close it and then press it down with my hands and it would latch. But if I hit a bump at highway speeds it would pop open to the secondary latch. Only happened twice but it was very scary when it happened.
That's exactly how I have mine set up, just push to shut - I'll try lowering my latch to a "soft slam" point and see how it works for me on the loop highway in town. Thanks for the tip!!
