RB hydraulic roller cam #2498797
05/21/18 10:04 PM
05/21/18 10:04 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I am thinking about putting a hydraulic roller cam in my 500" Indy headed -1 motor. It currently about 11:1 compression with a solid roller cam around .630 lift. Who has the best cam and lifters since this will be my first hyd roller motor?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: RB hydraulic roller cam [Re: 65 Hemi] #2498952
05/22/18 09:41 AM
05/22/18 09:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What RPM capability do you require? And what is your reasoning for switching from a solid roller to a hydraulic?
Re: RB hydraulic roller cam [Re: 65 Hemi] #2498961
05/22/18 10:08 AM
05/22/18 10:08 AM
an8sec70cuda Offline
I haven't assembled it yet, but Dwayne Porter (fast68plymouth) spec'd a hydraulic roller for my dad's 540" hemi project and we went w/ a set of Scorpion hydraulic roller lifters.
I've been VERY pleased w/ every other cam/head/valvetrain combo Dwayne has helped me with...no reason to think this won't work great.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499017
05/22/18 12:45 PM
05/22/18 12:45 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I have had great luck whit Morel roller lifter on 2 500 cube street engine but as stated before it hangs alot on how mutch you need to rev the engine!
Re: RB hydraulic roller cam [Re: Mopar Guy] #2499144
05/22/18 05:25 PM
05/22/18 05:25 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
It will be 100% street driven. It getting Holley Sniper 4500 EFI and AC.
Doug
MOPAR or NO CAR!!!
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499150
05/22/18 05:44 PM
05/22/18 05:44 PM
AndyF Offline
AndyF  Offline
Talk to Dwayne at Porter Racing Heads or give Brian at IMM a call. Both guys have experience with BB Mopar hyd roller setups.
I've run a few hyd roller cams in BB Mopar engines and it can be frustrating to get the cam lobe, lifter, rocker arm and valve spring all happy together. If you get it wrong the lifters will stop working early and the power goes away.
You shouldn't have much trouble finding a nice hyd roller cam but the lifters can be an issue. I run Comp lifters in my street car and they work just fine but there are guys who say they don't work. Morel has lifters, but I think that IMM uses Gaterman for their hyd roller lifters.
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499183
05/22/18 07:37 PM
05/22/18 07:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I went with the Morel High rpm versions, $940.00 from Hughes, they work good so far, car ran 11.33 @ 121, 4100 lb Charger, no tuning yet, they are a little noisy when cold, you can adjust them .020 from bottoming out of the plunger, & they also recommend no heavier than 5-40 oil, I am running 10-40 Lucas racing oil with no problems. pulls great over 6200.
my car is a street car.
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499189
05/22/18 07:51 PM
05/22/18 07:51 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
If it were me doing that i would go whit street lifter then and stay whitin there spring/rev limit for long life ! I have .600 on roller rockers 1,6 whit Morel street lifters and that engine is nice up
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499193
05/22/18 08:07 PM
05/22/18 08:07 PM
If it was me building your motor I would select a tight lash solid roller cam with a really good set of bushed solid roller lifter and matching valve springs, pushrods and so on.
Set them once when cold and again after running the motor long enough to get the oil and coolant temps. up to or above 160 F and reset the lash once more and enjoy the higher RPM of the solid roller cam and lifters with those good heads up twocents
I'm not a big fan of hydraulic roller lifters, yet, for either Mopar BB or 426 Hemi motors yet due to past bad experiences with hydraulic roller lifters in them down twocents
Re: RB hydraulic roller cam [Re: Cab_Burge] #2499216
05/22/18 09:07 PM
05/22/18 09:07 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
This right here!!!!👆👆
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: RB hydraulic roller cam [Re: CSK] #2499248
05/22/18 11:10 PM
05/22/18 11:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
do you think the lifter is operating like a hydraulic, or a solid?
Re: RB hydraulic roller cam [Re: BSB67] #2499299
05/23/18 01:01 AM
05/23/18 01:01 AM
SoCal
Brian Hafliger Offline
SoCal
We use Gaterman and Topline and have been very pleased with their performance.
Brian
Brian Hafliger
Re: RB hydraulic roller cam [Re: BSB67] #2499316
05/23/18 01:38 AM
05/23/18 01:38 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
more like a solid,but with dampening for the roller, no lash, so hopefully they will last longer on the street than all the horror stories of solids failing from street use, I said you can adjust them .020 from the bottom, mine are not done that way, mine are 1/2 turn from zero.
Re: RB hydraulic roller cam [Re: CSK] #2499318
05/23/18 01:41 AM
05/23/18 01:41 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run Howards.
4700 miles so far and lots of strip abuse. Only rated to 6500 rpm. I have the limiter at 6400.
'63 Dodge 330
11.19 @ 121 mph
Re: RB hydraulic roller cam [Re: GY3] #2499330
05/23/18 02:10 AM
05/23/18 02:10 AM
SoCal
SoCal
Originally Posted By GY3
I run Howards.
Gaterman supplies Howards with their link bar lifters for most applications.
Brian Hafliger
Re: RB hydraulic roller cam [Re: Cab_Burge] #2499460
05/23/18 01:27 PM
05/23/18 01:27 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Good advice given my experience with hydraulic rollers. Initially, my valve springs were not set-up properly and likely weakened quicker than normal too though. The valve train harmonics really beat up my rockers as a result of it. Even with all that going on the motor spun out 684 hp at around 5400 rpm before the springs lost control of the valvetrain.
Cab, thanks for the tip on checking the lash again with the motor warmed up. I haven't done that yet on my new solid roller valvetrain, but I will.
Dwayne Porter sure nailed the latest combo in my case too. My motor is running stronger than ever even with 2 full points less compression and burning California pump swill. I haven't dynoed it yet, but it sure runs a lot smoother now with the solid roller valvetrain.
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499602
05/23/18 06:12 PM
05/23/18 06:12 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
The more you rev the more you stress component and valve springs will set the bar for witch lifter you need to use !
If you build a street engine use street lifter for long life.
Re: RB hydraulic roller cam [Re: BradH] #2499923
05/24/18 12:00 PM
05/24/18 12:00 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I would like to keep the RPMs in the 3-6k range since that is a 100% street can that will never see the track again. I have other race cars when I have the urge. I will put between 10-12k miles per year on this car and drive it to work most days when the weather permits. I am looking for the reliability and about 600-650HP
Doug
MOPAR or NO CAR!!!
Re: RB hydraulic roller cam [Re: 65 Hemi] #2499935
05/24/18 12:20 PM
05/24/18 12:20 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I have a problem with understanding why someone needs a 650 hp motor that is only going to be street driven and never raced and wants to be reliable???? That is a lot of strain on parts to make that much power to be pounded on at low speeds for bragging rights. lie!!! and leave it stock. That's my .02. Don't get me wrong I like a lot of hp but i use it for what intended.
JAKES AUTOMOTIVE
Re: RB hydraulic roller cam [Re: JAKE68] #2499953
05/24/18 01:09 PM
05/24/18 01:09 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Lol. Well I didn’t say I wouldn’t drive hard! The reason I have is I have 3 other race cars and miss a little street action. I already had it built with a world block, decent parts and -1 heads and drive it maybe 500 miles per year. So instead of building a new motor I should use the parts I have. I would think it should be possible to make 600hp out of a 500” motor and be very reliable.
Doug
MOPAR or NO CAR!!!
