Re: Vacuum advance
[Re: volaredon]
#2499149
05/22/18 05:43 PM
05/22/18 05:43 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
That means it can pull up to 11.5 degrees in the distributor at full vacuum, or 23 degrees at the crank.
The old one (before it blew) was pulling 17 degrees at the crank at full vacuum, unless it had an internal hex adjuster and was set to something lower.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Vacuum advance
[Re: volaredon]
#2499217
05/22/18 09:10 PM
05/22/18 09:10 PM
RapidRobert
You will be fine with this new one. As noted it has 6 deg less adv but it is a non issue right now.
Re: Vacuum advance
[Re: Secret Chimp]
#2499719
05/23/18 10:57 PM
05/23/18 10:57 PM
Posts: 2,225 ILLINOIS
volaredon
ILLINOIS
The old one (before it blew) was pulling 17 degrees at the crank at full vacuum, unless it had an internal hex adjuster and was set to something lower. I think you have this backwards. the old one was the 11.5. I have seen the allen screw adjuster in the vac nipple on vac advance cans before. what does this adjust? Can I make the 8.5 act like the 11.5? Does it change the inches of vacuum that it kicks in at? or same amount of degrees of advance, regardless of where the setscrew is adjusted, at a different vac level or RPM or load?
Re: Vacuum advance
[Re: volaredon]
#2499726
05/23/18 11:06 PM
05/23/18 11:06 PM
Secret Chimp
Eugene, Oregon
The old one (before it blew) was pulling 17 degrees at the crank at full vacuum, unless it had an internal hex adjuster and was set to something lower. I think you have this backwards. the old one was the 11.5. I have seen the allen screw adjuster in the vac nipple on vac advance cans before. what does this adjust? Can I make the 8.5 act like the 11.5? Does it change the inches of vacuum that it kicks in at? or same amount of degrees of advance, regardless of where the setscrew is adjusted, at a different vac level or RPM or load? The adjuster determines how much vacuum you need to start pulling advance and what the ultimate maximum is. Basically, you are adjusting a vacuum vs spring resistance curve. You can't make the 8.5 act like the 11.5, but you could squinch an 11.5 down to act kind of like an 8.5. Whenever I monkey with this stuff, I like referring to this topic: http://www.dodgecharger.com/forum/index.php?topic=14888.0It has very good detail and an example table showing changes for going CW vs CCW with an example canister - once you have a Mityvac-type thing and a timing light on the engine, it is pretty quick to figure out your ideal adjustment.
Re: Vacuum advance
[Re: volaredon]
#2499789
05/24/18 01:01 AM
05/24/18 01:01 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The answer is maybe. Of the three variables, the spring rate can not be changed. The pre-load (allen adjuster) changes the vacuum need for the advance to start. The maximum advance is limited by the tabs on the arm. https://www.forabodiesonly.com/mopar/ams/how-to-limit-and-adjust-chrysler-vacuum-advance-cans.183/
