Trick Flow Valley Pan Install ???
#2498903
05/22/18 02:09 AM
05/22/18 02:09 AM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Hello all,
I am installing TF270 heads on my RB and want to know about the Trick Flow Valley pan installation. Do I have to have one of the heads removed to install the Valley pan? I have a 2 piece Hughes valley pan and don't like the very large gaps under the heads. The Hughes pan worked very well with my Stealth heads and I never even gave it a second thought. Well I bolted the TF270 heads on and now I have a gap. The gap is so big the I am not sure RTV is going to do any good. So if I get the TF valley pan do I have to remove one head to install it and do they fit tight enough that the large gap disappears?
Thanks,
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Trick Flow Valley Pan Install ???
[Re: Digger73]
#2498912
05/22/18 03:21 AM
05/22/18 03:21 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
not the full answer . I have the TF pan on my Source heads and use Andy's batwings seals tight as . The TF pan is quite thick and I believe it will sit under the TF270 raised port , should only need a bead of sealant . I would try sliding it in from the front if your heads are on
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Digger73]
#2499012
05/22/18 12:39 PM
05/22/18 12:39 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I haven't had the TF pan in my hands, but if it's the same as the Indy cover...... You can probably get it installed okay the first time without removing a head by sliding it in from one end under the heads.
The heads have an extended intake flange which overhangs the cover.
[Re: Digger73]
#2499037
05/22/18 01:29 PM
05/22/18 01:29 PM
Posts: 1,030 ohio
67mprfan
ohio
On my Indy headed motor I cut strips of gasket paper with rtv and it sealed up good
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Digger73]
#2499103
05/22/18 03:43 PM
05/22/18 03:43 PM
Digger73
Portland, Oregon
Thanks all for the answers/suggestions. I just got the heads installed along with the headers and was trying to avoid having to redo what I just did. I was hoping that someone had already tried the slip it in from the front idea before me. I am just not very confident in the 1/4" gap being able to seal with RTV. I do have some gasket material that I might try the strip and RTV idea.
Thanks again,
Digger73 (Mike)
[Re: Digger73]
#2499175
05/22/18 07:24 PM
05/22/18 07:24 PM
Posts: 1,030 ohio
67mprfan
ohio
Thanks again,
If you try it let it sit B4 putting the heads on or it will push all the rtv out just a friendly reminder
Digger73 (Mike)
