I'm not looking to replace the arms/blades as I want to keep the originals. I just need the rubber refills but need the type that will fit my blades. The ones I bought are too narrow and won't stay in the blades. They also don't have the compressible metal tabs that lock them in.
Exactly.
None of those look like or fit the Anco push button type blades.
Freshest rubber and best fit will be from whomever makes the blades for Classic Industries. Give them a call or shoot them an e-mail. Tell 'em you refills for their 15" blades, just like they sell for the 16" blades.
Freshest rubber and so-so fit will universal refills with the spring clips on the end. I've used them for years. IIRC this is Trico's "43" series, p/n 43-150. I've had universals from Anco (Anderson Comp.) with the spring clip tips that also worked. Not sure of the part numbers as didn't think this would ever be needed so I didn't keep track...
Older rubber, correct fit, will be Trico LP (latch pin) refills, or Anco PB (push button) refills. So interchange is
Trico LP-15
Anco 680
ANCO 12-15
NAPA 16-1512 (not verified with an actual example)
