Identifying a 440s year and original vehicle type? #2498228
05/20/18 02:13 PM
05/20/18 02:13 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I bought a 1971 Dodge crew cab that was originally a 383 truck. It has a 440 in it and I’m trying to identify the year and if possible what it came out of.
On the top pad it reads H 440. Below that is
8. 10
If I checking codes correct the H means a 1972 block?
However the build date on the pass side of the block looks like 1971.
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498230
05/20/18 02:14 PM
05/20/18 02:14 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Another
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498231
05/20/18 02:15 PM
05/20/18 02:15 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Wouldn't that mean it was built in 71 and installed in an early 72?
Re: Identifying a 440s year and original vehicle type? [Re: stumpy] #2498233
05/20/18 02:19 PM
05/20/18 02:19 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Check the VIN pad on the passenger side of the block just above the oil pan, that will tell you what vehicle it came out of.
JB Rhinehart, Realist
A-Body's RULE!
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498236
05/20/18 02:21 PM
05/20/18 02:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 1972 model year started during the Summer of 1971.
H is the Series (model year) 1972
Is there a partial VIN on the passenger side of the block?
Re: Identifying a 440s year and original vehicle type? [Re: Alaskan_TA] #2498244
05/20/18 02:29 PM
05/20/18 02:29 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Where on the pass side?
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498246
05/20/18 02:33 PM
05/20/18 02:33 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here,lower right front above oil pan.And for what it's worth,this is a 71 Hp block with a 7/69 casting date.
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498252
05/20/18 02:42 PM
05/20/18 02:42 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I cleaned all along the edge above the pan and can’t find anything
Re: Identifying a 440s year and original vehicle type? [Re: 62maxwgn] #2498253
05/20/18 02:43 PM
05/20/18 02:43 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thx I will go check again
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498260
05/20/18 03:06 PM
05/20/18 03:06 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Ok so the center pad had the number
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498261
05/20/18 03:07 PM
05/20/18 03:07 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
2C105122. C body I’m assuming ?
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498264
05/20/18 03:13 PM
05/20/18 03:13 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Might mean plant where built.
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498265
05/20/18 03:14 PM
05/20/18 03:14 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yep a 72 C Barge
Re: Identifying a 440s year and original vehicle type? [Re: RUMBLON] #2498277
05/20/18 03:48 PM
05/20/18 03:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
C plant is Jefferson, MI so it had to have been in a C body or Imperial originally.
