Bud Weaver @ sixpack solutions #2498174
05/20/18 12:21 PM
05/20/18 12:21 PM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
How do you get in contact with Bud Weaver
Sixpack solutions
Was wanting to get those idle screws and tool ?
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498223
05/20/18 02:03 PM
05/20/18 02:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sixpack solutions
Bud's address is:
Forrest Weaver
832 East H street
Ontario, California
91764
his Email:
supr69bee@roadrunner.com
And IIRC Scott Smith (Harms Automotive) was carrying Bud's six-pack solution set screws and tool...
Mike
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498232
05/20/18 02:17 PM
05/20/18 02:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Bud moved to Texas and quit making the screws, I believe he had health issues.
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498255
05/20/18 02:48 PM
05/20/18 02:48 PM
Sharpsburg Maryland
Sharpsburg Maryland
Dam it just my luck
Can they be had elsewhere
What exactly where they 8-32 screw with that tapered end with a set screw head or hex head ???
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498257
05/20/18 02:49 PM
05/20/18 02:49 PM
Sharpsburg Maryland
Sharpsburg Maryland
Scott do you carry them?
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498326
05/20/18 06:23 PM
05/20/18 06:23 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Dam it just my luck
Yes 8-32 thread, and they were Allen head set screws with the ends turned to match the needle seat angle, if you have access to a lathe you could make your own, the tool could be fashioned from a ball head Allen wrench and a compression spring
Mike
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498332
05/20/18 06:39 PM
05/20/18 06:39 PM
Sharpsburg Maryland
Sharpsburg Maryland
Wow thanks for the info
I'm a machinist
I'll make a couple sets no problem
The one in the carb had broke
I guess that tool looks like a extended ball allen wrench
I did know if it had some type of cable on the end to help get in there -like a speedometer cable thanks for the pics they do the trick and I can get going on this thing
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498333
05/20/18 06:42 PM
05/20/18 06:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct.
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498334
05/20/18 06:43 PM
05/20/18 06:43 PM
Sharpsburg Maryland
Sharpsburg Maryland
I'm a machinist
I didn't know if it had some type of cable on the end to help get in there -like a speedometer cable thanks for the pics they do the trick and I can get going on this thing
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498372
05/20/18 08:50 PM
05/20/18 08:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'm a machinist
There was one version where Bud had cut the end of the Allen ball end wrench, about an 1 1/4" off and reattached it with a stiff compression spring to join the pieces together by just sliding the spring over the two ends so it could flex... but this was his latest tool below
Mike
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2498397
05/20/18 10:08 PM
05/20/18 10:08 PM
Sharpsburg Maryland
Sharpsburg Maryland
Ok thanks I work on it tomorrow
Thanks for the help
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2577978
11/13/18 04:39 PM
11/13/18 04:39 PM
long island
Dart 383 Offline
Dart 383  Offline
long island
Place a want ad...
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2578141
11/13/18 10:48 PM
11/13/18 10:48 PM
long island
Dart 383 Offline
Dart 383  Offline
long island
hi,
was wondering if you ever got to make any tool and screw that worked on the end carbs .
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2578230
11/14/18 01:46 AM
11/14/18 01:46 AM
long island
Dart 383 Offline
Dart 383  Offline
long island
any luck with making these screws?
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2578274
11/14/18 08:57 AM
11/14/18 08:57 AM
Sharpsburg Maryland
Sharpsburg Maryland
Yeah made the screws and tool
ended up makin the tool out of a ball allen wrench and a speedometer cable works fine
I don't have a pic right now but made steel sleeves to go from the seedo cable to the allen wrench and then to a small handle
Im at work now if I can remember ill take a pic and try to post this evening
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2578414
11/14/18 03:49 PM
11/14/18 03:49 PM
long island
Dart 383 Offline
Dart 383  Offline
long island
great very interested
Re: Bud Weaver @ sixpack solutions [Re: 440farmer] #2578938
11/15/18 09:24 PM
11/15/18 09:24 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
What length screw? Did you use a stainless steel screw?
Real Men shift for themselves
