A990 reproduction parts ? #2498075
05/20/18 12:32 AM
05/20/18 12:32 AM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
I'm suppose to be getting a 65 Coronet sedan that has been made into a pro street car. I'd like to make some changes and make it look more like an A990 car. I probably can't afford the single headlight setup....any other ideas ? Also....I was thinking steel rear wheels and the cast grey cragars on front with polished rim.....any other wheels ideas ? Any suggestions ?
J.C. Childress (434) 665-9541
Re: A990 reproduction parts ? [Re: JC Childress] #2498097
05/20/18 01:42 AM
05/20/18 01:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Google A990 photos. Lots to look at.
Re: A990 reproduction parts ? [Re: JC Childress] #2498433
05/20/18 11:12 PM
05/20/18 11:12 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Get some front seats out of an old Dodge van, remove th rear seat and put in an 8 point roll bar. Get the correct hood scoop.
Re: A990 reproduction parts ? [Re: JC Childress] #2498492
05/21/18 02:06 AM
05/21/18 02:06 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The single-headlight grilles were made from cutting sections out of another grille, cutting the hi-beam section out of the headlamp bezels, and overlaying the grille section; if you look at old photos, they didn't line up flush.
Front mag wheels had straight spokes, I think ET makes aluminum replicas.
The more clever, difficult and/or spendy stuff is the RO/WO race interior, RN123 shifter lens, the Plymouth (1" -shorter) wheelbase on Dodges, and the exhaust system. Some had 1-piece door glass. The rarest, most coveted & expensive race piece is probably the stainless K, but there's probably only 1 or 2 left worldwide. They were blamed for what was actually rear axle deflection and they were swapped back to the "production" piece.
