changing cat whiskers on a 69 b body question #2496157
05/14/18 09:08 PM
05/14/18 09:08 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
would like to change the cat whiskers on the side windows of my 69 road runner . Problem is car is not torn apart . any ideas?
Re: changing cat whiskers on a 69 b body question [Re: 3wracing] #2496209
05/14/18 11:17 PM
05/14/18 11:17 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Use lots of masking tape over the edges and take your time... I do them after glass, so no difference if it's all together otherwise or not.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: changing cat whiskers on a 69 b body question [Re: 3wracing] #2496265
05/15/18 12:52 AM
05/15/18 12:52 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Way easier if you go inside the door, lower the bottom stop for the window, and drop the window as low as you can. Ditto the masking tape.
Re: changing cat whiskers on a 69 b body question [Re: 3wracing] #2497943
05/19/18 06:38 PM
05/19/18 06:38 PM
Chicago
PurpleBeeper Offline
Chicago
I like topside's idea...much more room without the glass in the way.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: changing cat whiskers on a 69 b body question [Re: 3wracing] #2497949
05/19/18 06:58 PM
05/19/18 06:58 PM
Lee Co. Fla.
5carguy Online content
5carguy  Online Content
Lee Co. Fla.
X3
Re: changing cat whiskers on a 69 b body question [Re: 3wracing] #2498431
05/20/18 11:05 PM
05/20/18 11:05 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Go inside the door and figure how to lower the window further for better access not only for installing but also for removing
Re: changing cat whiskers on a 69 b body question [Re: 3wracing] #2498460
05/21/18 12:27 AM
05/21/18 12:27 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
You'll have to lower the glass down past them, otherwise there won't be any room for you to pull or put back on... I figured that was a given laugh2
