Re: Scuffed Piston/Bore? [Re: Blusmbl] #2497744
05/19/18 12:06 AM
05/19/18 12:06 AM
BigFish69 Offline
BigFish69  Offline
Should of sold it to me
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2497828
05/19/18 12:04 PM
05/19/18 12:04 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
that scuffing could have been from initial fire up - as in lack of oil on the skirts and possibly honing grit left in the bores. I would re-hone it and scuff the pistons skirts with a scotch brite and stick it back together. How did the bearings look that will give you an indication of a dirty assembly
Re: Scuffed Piston/Bore? [Re: DoubleD] #2497837
05/19/18 12:25 PM
05/19/18 12:25 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
More debri in the bearings than I would like to see for what is supposed to fresh.. Pan was spotless.
So I can only assume the pan has been off and cleaned.
Possibly too dry on start.
I can imagine a scenario where the cyl.s were washed down,from sticking floats,timing wasn`t right or ignition. Cranked it forever over who knows how many attempts/days before actually getting it running..
It is getting honed,fresh bearings/rings and back together.
Cheap insurance versus damaging a new block and assembly.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2497847
05/19/18 12:49 PM
05/19/18 12:49 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Sounds like a solid plan - and yes those blocks are becoming very difficult to find! This going in the GTX??
Re: Scuffed Piston/Bore? [Re: DoubleD] #2497869
05/19/18 01:33 PM
05/19/18 01:33 PM
N.E. Ohio
N.E. Ohio
Yep,I really got a deal on it.
No ,into the Cuda`.
Haven`t had it running in 4 years.
Having a 10-point cage installed and going into the 9`s permanently.
Shopping around for a cam for it.10.77cr 330cfm heads,4.15 crank/4.32 bore.
So many choices and opinions,more confusing than a mail order bride.LOL
How are your projects?
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2497882
05/19/18 02:30 PM
05/19/18 02:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not an isolated cylinder so lack of oil to coat walls, metal in the oil, check the cam for wear, might have wiped and been replaced, same with lifters, "pan clean" reason you got it cheap.
I'd go for hone and new pistons-rings, thorough clean job.
Re: Scuffed Piston/Bore? [Re: cudaman1969] #2497885
05/19/18 03:10 PM
05/19/18 03:10 PM
N.E. Ohio
N.E. Ohio
Possibly.
Cam is already in the trash can.
Looks like a roller going in.
Bought it for the block.
Anything else reusable is a plus.
Has a nice set of ported 906 with big valves I need to find a home for.
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2497989
05/19/18 08:47 PM
05/19/18 08:47 PM
The Ross pistons have very delicate skirts on them, its the alloy shruggy They will look bad but measure okay scope shruggy
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2498184
05/20/18 12:33 PM
05/20/18 12:33 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I hear ya Dennis - best thing to do is ask an expert - too many keyboard advisers that never built an engine giving advice makes it even tougher!
If your going roller - I have some cam specs from that 512 I built - that might be what your looking for
The hefty just got its chassis certification good to 8.50 - it's almost ready to go - just gonna do some touch up on the primered spots - did not get a chance to do the paint this year - should be out soon
Re: Scuffed Piston/Bore? [Re: DoubleD] #2498187
05/20/18 12:40 PM
05/20/18 12:40 PM
N.E. Ohio
N.E. Ohio
Cool,glad to hear you are still in the fight.
I would interested in your cam spec,,,thanks
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2498194
05/20/18 01:12 PM
05/20/18 01:12 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Thats not uncommon for those Ross pistons IMO.
RIP Monte Smith
Re: Scuffed Piston/Bore? [Re: 6bblFLASH] #2500284
05/25/18 12:53 PM
05/25/18 12:53 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Can you check the piston diameter right at the pin and then at the slipper tip. Kinda looks like the slipper has collapsed. Could have been some piston rock.
