Page 3 of 3 1 2 3
Re: Engine condition Opinions? [Re: Mr onetwo] #2497817
05/19/18 11:18 AM
05/19/18 11:18 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I hate being the buzzkill on this post but...........
Those speed pro pistons are absolutely horrible. They are extremely heavy and won’t do your old “maybe they will be ok with those heavy pistons stock connecting rods” . I’ve been doing this long enough to know that you really need to consider spending some money to build the 440 correctly.
Here are some bare minimums that I would consider mandatory:
Purchase lightweight forged pistons/ KB 237 piston would be a decent option as well to save money.
Have the stock rods resized with new ARP bolts.
Have the rotating assembly balanced.
Re: Engine condition Opinions? [Re: ccdave] #2497830
05/19/18 12:08 PM
05/19/18 12:08 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you change pistons, it really should be re-balanced. And new rod bolts and resizing the rods is also a very good idea. There goes a few hundred dollars.
How far out of spec are the cylinder bores? Keeping in mind that the budget is the prime motivator, why not just re-ring it?
If the cylinders aren't a train wreck, you might think about a hone job and throwing some new rings in along with new bearings and calling it good.
Way back when, we used to do that all the time. I remember knurling pistons that were way out of spec for the cylinders. It worked well in low speed applications. You can get several years out of a cheapy job like that if the pistons don't flop around in the cylinders too much. And of course, they make rings just for this.
It might be best to either do a full-on economy assembly or a full-on re-build. Not something in between.
Master, again and still
Re: Engine condition Opinions? [Re: DaveRS23] #2497840
05/19/18 12:27 PM
05/19/18 12:27 PM
Coastal Maine
Mr onetwo Offline OP
Coastal Maine
Budget frown I just wanna drive my truck a bit this year!The guy said it was just inside .007 spec is .005 to .007 I guess.I would love to do exactly as you say Dave.I will call them Monday morning.
i can save a bunch of money by using Enginetech bearings as opposed to Clevite 77...thoughts?
Re: Engine condition Opinions? [Re: Mr onetwo] #2497851
05/19/18 12:56 PM
05/19/18 12:56 PM
Coastal Maine
Coastal Maine
I forgot...here is a couple of videos of the actual engine running and the truck driving.Keep in mind there is a broken header tube , so a bad leak.Listen and tell me what you think.Thanks 1st run after sitting for years https://www.youtube.com/watch?v=TsCII5P99vc after tuneup https://www.youtube.com/watch?v=VjkuQH5NZc0 driving around https://www.youtube.com/watch?v=TVF3z5sacmo
Re: Engine condition Opinions? [Re: Mr onetwo] #2497935
05/19/18 06:21 PM
05/19/18 06:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Skip the EFI, put the money inside the engine.
Boffin Emeritus
Re: Engine condition Opinions? [Re: Mr onetwo] #2498010
05/19/18 10:03 PM
05/19/18 10:03 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Good oil, proper clearances, and low RPM doesn't require premium parts to live.
Re: Engine condition Opinions? [Re: DaveRS23] #2498013
05/19/18 10:09 PM
05/19/18 10:09 PM
Coastal Maine
Coastal Maine
Dave, what do you think of this Howard's grind?
Re: Engine condition Opinions? [Re: Mr onetwo] #2498124
05/20/18 08:13 AM
05/20/18 08:13 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
As stated the 2266 piston is terrible. They will be at least.060 -.080 in the hole. With an iron open chamber head thats a bad combo. No compression no quench. It'll run but it won't be efficient. You should try to get a piston with a 2.060- 2.065 compression hgt. Get your short block together then pic your cam. Do it right or you may pay later. Ask me how I know..
America First!
Re: Engine condition Opinions? [Re: Mr onetwo] #2498173
05/20/18 12:09 PM
05/20/18 12:09 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
That is certainly a mild cam. Why not just us a stock, original cam? There are a lot of them lying around and they have proven themselves to be very reliable.
Re: Engine condition Opinions? [Re: carnut68] #2498182
05/20/18 12:33 PM
05/20/18 12:33 PM
Coastal Maine
Coastal Maine
Well you bastards smile talked me into it, I have decided to invest in the bottom end of this motor. I am going to get a set of Wiseco Pro Tru pistons and moly rings #PTS531A3. Only $92.77 more than the stock 350np's @ $411. I am also going to buy the 440 Source rods at $250 and use Clevite 77 bearings. I've already got a Melling HV oil pump. What other suggestions do you have to spend my money on this bottom end? smile I will use mls head gaskets to reduce the CR a bit and probably use the Howards RV cam with all stock valve train parts.I am not going to put another dollar into the heads,intake ect.Please feel free to tell me what I am forgetting/missing...many thanks!
Re: Engine condition Opinions? [Re: DaveRS23] #2498186
05/20/18 12:37 PM
05/20/18 12:37 PM
Coastal Maine
Coastal Maine
I am going to get the Summit SUM-6400 cam and lifter kit as it is better than stock and you can't beat the price at $117.My question is how should I install the cam for my application...straight up or advanced?Also, it is a cast crank motor...what should I do about balancing?I don't have the rods yet, but when they arrive I will weigh both new and old assemblies and post up the difference.Also any thoughts on what I should do about a distributor and the ignition timing.Thanks in advance for your help!
Re: Engine condition Opinions? [Re: Mr onetwo] #2500575
05/26/18 08:46 AM
05/26/18 08:46 AM
Coastal Maine
Coastal Maine
stock weight 1940 grams
Re: Engine condition Opinions? [Re: Mr onetwo] #2500805
05/26/18 09:50 PM
05/26/18 09:50 PM
I would install the cam so the intake lobe centers at max lift are from 109 to 106 after top dead center(what ever you can get up) , that will advance the cam from 3 to 6 crankshaft degrees and increase the bottom end HP and torque as well as giving up some power above 5000 RPM shruggy work
On the ignition I would recurve the stock distributor if it has mechanical advance built in it so it has between 14 to 18 degrees at idle and no more then 36 degree total advanced revved up high enough to make sure the mechanical advance is maxed out scope up twocents
Mr gasket sells the advance springs so you can change them to make the advance come in sooner, another help on low RPM power up
Re: Engine condition Opinions? [Re: Mr onetwo] #2500911
05/27/18 07:47 AM
05/27/18 07:47 AM
Coastal Maine
Coastal Maine
Thank you Mr.Cab, any thoughts on balancing?
Re: Engine condition Opinions? [Re: Mr onetwo] #2500961
05/27/18 11:47 AM
05/27/18 11:47 AM
I would have it done by a good shop up
There are two different weights involve in rotating assembly, the individual and total weights of each reciprocating and rotating parts and the rotational weights of the components, this is probably not the correct terms to describe what I mean but if you don't own or have access to a good automotive balancing machine have a good shop balance the rotating assembly for you up
Re: Engine condition Opinions? [Re: Mr onetwo] #2506489
06/10/18 07:39 AM
06/10/18 07:39 AM
Coastal Maine
Coastal Maine
Finally got all my stuff back from the machine shop, but I have 2 stupid questions.Is the rear most cam bearing supposed to have 1 oil hole or 3?The 1 oil hole in it is not aligned perfectly either...I am not to happy.I can't look at a set locally as no one has one in stock.Also, the block came back with nothing done to the chamfer at the top of the bores.You can actually feel a ridge at the very top.The block was not decked so it was like this from the factory.The Don Taylor book mentions that you can do this your self.Thoughts?
Re: Engine condition Opinions? [Re: Mr onetwo] #2506517
06/10/18 11:14 AM
06/10/18 11:14 AM
cam bearings only need a 1/16" dia lube hole so if you have that much area left from how they clocked em you are fine but it would make me wonder about their meticulousness cuz that operation is a no brainer. any more than that is a waste of precious psi & the as produced cam bearing drilled hole is much bigger than 1/16" (the 2 that feed the heads-1/8" needed).
Page 3 of 3 1 2 3
